Quoted from Aniraf:
Is there any simple way to fix a stationary target that has a loose stack? I have one that keeps leaning to the side because of this :/. [quoted image]
Well, I replaced the target with a new one that thenotrashcougar recommended from PinballLife. I now have perfect stationery targets
. I am also fairly prod of myself for not f’ing it up.
spookycharlie I did have a question about how you manufacture these…I noticed that the wires soldered to the target are continuous. There is no cut in the wire where it solders onto the target. Instead the shielding is perfectly cut off the wire, then the wire is folded over the target and neatly soldered to the pole. How do you do that?
