New! Dark mode!
(Topic ID: 195784)
Total Nuclear Annihilation Club...Welcome to the future!
By Pinballlew
  • 7,251 posts
  • 523 Pinsiders participating
  • Latest reply 19 hours ago by Pinballsoul
  • Topic is favorited by 213 Pinsiders
There have been 1,162 images uploaded to this topic. (View topic image gallery).
23 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 7251 posts in this topic. You are on page 59 of 146.
#2901 2 years ago
Wow - what a game.
FWIW my psu was set correctly for here in Australia and I was able to check with a small mirror and taking a photo of the reflection with my phone.
Does anyone else feel like they get more reactor chute rejects than they should? Any known tweaks for that?
#2902 2 years ago
Quoted from dmj1977:
Wow - what a game.
I got a ton of rejects. I've largely solved that problem by gently bending the scoop opening down.
#2903 2 years ago
Wow - what a game.
Almost always rejects from the right flipper. Left Flipper about 50%. Now I mostly shoot into the reactor and drop in from the top side.
#2904 2 years ago
Quoted from cooked71:
More
How is the wood looking on the outside of the scoop?
#2905 2 years ago
I get quite a few rejects too, even when coming from the upper playfield. It's almost like a lip out in golf. Starts to fall then skirts on past. When it's lit, I really try to settle things before letting it fall controlled into the scoop. Haven't done a whole lot of tweaking with anything though, so it honestly could just not be setup 100% correctly.
#2906 2 years ago
Guys what level do you keep this game? Assuming it's not 6.5
#2907 2 years ago
Quoted from delt31:
I'm at 7.2
#2908 2 years ago
#150 is in the house!!!!! (Garage, technically)
#2909 2 years ago
Quoted from delt31:
We have it on 6.5, on location. Seems fine to me. I'll check the audits later today to see what the average game times are like.
#2910 2 years ago
6.7 or 6.8 I think. On location.
#2911 2 years ago
Is there a reason to purchase the accessory power supply on pinball life website. What is available that you would have to plug in?
#2912 2 years ago
Quoted from estrader:
You may need it for electric mods like the Hooked On Pinball side armor light kit.
https://www.hookedonpinball.com/store/p115/Total-Nuclear-Annihilation-TNA-Side-Rail-Illumination-Kit-Pinball-Mod
Just a note re: Robert @ HOP
He is an excellent guy. Totally went above and beyond when something went sideways that wasn't either of our faults. Shop with confidence!
#2913 2 years ago
Quoted from fnosm:
You don’t need it for the light rails... there’s a factory connector that works fine
#2914 2 years ago
So, if I have the light rails, speaker lights, shaker and knocker will I need the accessory power supply?
#2915 2 years ago
Quoted from Jakers:
I can't say for sure but since the speaker lights, knocker and shaker are installed at the factory I think you might need this for the rail lights.
#2916 2 years ago
You'll need it for leg light ups, lighted buttons, and likely any new mod down the road.
#2917 2 years ago
Quoted from Toads:
Mines holding up perfectly - no problems. Was thinking of lowering the scoop a fraction as suggested by Scott.
#2918 2 years ago
Quoted from Jakers:
For all of those, no. I had all but the light rails installed at Spooky. And installed the rails on my own... there was a spare port in the back of the cabinet
#2919 2 years ago
Mines starting to ware on the sides...
#2920 2 years ago
Quoted from Toads:
Battle scars!
Gives the game character and shows it has history.
#2921 2 years ago
Anyone else having a problem with the sling arms getting stuck sometimes in the forward position? It’s NOT the coil locking on, just the arm isn’t pivoting that smoothly and gets stuck, especially if the ball hits the rubber as such to push the arm slightly to the side as it moves. This behavior has occurred on three different slings. Tried adjusting the coil angle slightly to allow for smoother movement and it helped to a point. Just set the game up tonight and I’m in love with it, only wondering if others have had this issue.
#2922 2 years ago
Do you have a link to where this was suggested and/or do know if the suggestion was to bend the scoop or lower the whole thing somehow?
-thanks
#2923 2 years ago
Quoted from riggy469:
Make sure the 2 screws that hold the coil are tight and that the bracket that those 2 screws hold is not crooked . Seems like you've got something loose and it is binding .
#2924 2 years ago
-thanks
https://pinside.com/pinball/forum/topic/total-nuclear-annihilation-cluball-welcome/page/55#post-4416259
#2925 2 years ago
So worth the wait. After making the deposit last August, #183 was delivered today. Game was beautiful and working so well right out of the box. Only one slight adjustment to a sling switch to increase sensitivity. Other than that, seems to be working flawlessly.
Thank you very much Scott and everyone at Spooky. Co-op and versus mode really take this game over the top!
2F2EE005-C6A8-4E56-8EA0-237DDFD95148 (resized).jpeg39C474EB-B531-4814-9B0A-8D6E6B0FBF6F (resized).jpeg
#2926 2 years ago
Congrats, enjoy. 3 million isn't a bad score for having so little time!
#165, get on a truck!
#2927 2 years ago
Quoted from oyvindmo:
Avg. game time: 2:57. It has been on location for about two weeks now; I expect the average time to rise 5-10% over time as the regulars learn the machine better.
#2928 2 years ago
Yes, we had a report yesterday about it happening once on ours as well. Haven't looked into it yet, beyond confirming that it wasn't the coil locking on.
#2929 2 years ago
Quoted from trilogybeer:
Yeah, we tried loosening them a tad, shifting the coil slightly to allow for smoother movement through the coil, and then tightened them up. Things are better but we still get the occasional bind up. There seems to be some slight side to side play on the arm, not sure if that’s normal or not.
#2930 2 years ago
Are we up into the 300's yet?????
#2931 2 years ago
The coil sleeve should go through that bracket and be sticking up past it . If your coil seeve is a bit short it won't hold the coil secure in the center . As for side to side a small amount is normal , but you should make sure that you are not missing any E clips at pivot points .
#2932 2 years ago
Thanks, I’ll take a peek under the playfield after work later today.
#2933 2 years ago
Da fuq?!
#2934 2 years ago
Holy crap. You destroyed all 9 reactors????
#2935 2 years ago
I will never see something like that with the glass on. Amazing!
Edit: Scott, please increase the balls per game setting to a maximum of 100. It is my only chance!
#2936 2 years ago
Quoted from 27dnast:
LOL!
If by "you" you mean Bowen, sure. That pic was posted on Spooky's FB page.
As for me, my high score is only 4.8 million so far (factory settings).
To me, that score is beyond comprehension.
#2937 2 years ago
player one got totally annihilated .
#2938 2 years ago
Quoted from RobT:
LOL!
I was going to say, Rob... SELL IT
Try bumping from factory to hard in settings... see what you think. I've gotten past reactor 3 in Hard... but after that I just fall apart. I think, tho, the game is more fun with the added avalanche of difficulty.
-Todd
#2939 2 years ago
Can someone describe for me how the Team Vs Mode is supposed to work? I was playing it a few days ago and noticed that my team couldn't progress beyond reactor three until after it was destroyed by the other team. It was critical, but no buttons were illuminated for destroy. I did also shoot the shots that were illuminated for the other team, but that didn't do anything. To be honest, I wasn't paying much attention to how it was working until this happened, so perhaps it was doing that for the other reactors too. Is this normal?
#2940 2 years ago
Quoted from lpeters82:
No, that's not how it's supposed to work. Make sure you play in the correct order. Player 1 and 3 are one team, and 2 and 4 are the other. Once you have Team Vs mode started, you need to add all four players. Progress is shared between 1 and 3 and 2 and 4, but they are totally independent of each other otherwise.
#2941 2 years ago
Hmm...I think it may be a bug caused by starting the mode incorrectly. We started out playing Coop Mode. Four players were added and Player 1 played their ball. The start button was then held, which switched it to Team Vs Mode (I wasn't expecting that to happen). From then on the reactors seemed to progress as if in Coop Mode, meaning that as reactors were destroyed they were destroyed for both teams. However, as previously noted if a reactor was critical no shots were illuminated for destruction for the other team. The scores were still keeping track as 1 and 3 vs 2 and 4.
PS: On a side note. I wouldn't mind seeing Team Vs Mode to accept 1 and 3 vs 2 alone. I have a number of non-pinhead friends and that might create a fun handicap mode.
#2942 2 years ago
Hey crile1 remember when you told me to calm down two weeks ago because I said I just paid up and my game was shipping in two weeks... and you were all like nah that's not gonna happen. Well, it did. It's on a truck and heading my way
Time to bust out glow sticks, shit just got real!
#2943 2 years ago
Glad to hear it. Looks like production has picked up speed lately.
#2944 2 years ago
Quoted from Whysnow:
A good thing to do to make your pop bumper more sensitive is to raise the ring so the ball has the ability to move the skirt more easily.
This is done by adding a washer to each rod.
rough drawing help explain
My pop number seems to be missing a few hits as well. I’m not the most capable at pinball repairs/tweaks but I’m nothing if not enthusiastic
Any other advice on how to do this? Or should I get stuck in and post pics of how I made it worse later?
#2945 2 years ago
Mine is shipping Monday!!! Happy Days!!!
#2946 2 years ago
Quoted from BladeFury:
Whoah you have all the new hits, congrats!
#2947 2 years ago
Quoted from GorillaBiscuits:
It was time for a shuffle
#2948 2 years ago
You own four pins? Time to bust off two nuts and add on two washers.
I think you will be just fine. Do it with the power off if that is not obvious.
#2949 2 years ago
You just need to tighten the switch gap under the pop. It’s actually easiest done with the switch assembly removed (but can be done with it screwed to the playfield).
Make sure you turn the power off.
Trial by errror process
#2950 2 years ago
Mine too. PLAN THE PARTY.
Hookedonpinball.com
6,550
Fort Collins, CO
$ 279.95
Pin Stadium Pinball Mods
$ 279.95
6,150
Sale Pending!
St Paul, MN
6,000
Sale Pending!
Lutz, FL
$ 3.50
Pinball Mod Co.
$ 86.95
6,400 (OBO)
Rancho Mirage, CA
