Quoted from Gogojohnnyquack:I'm preparing to follow Scott's advice on adding a spacer to the 10" sub and then sealing the enclosure - Can someone please point me to an appropriate spacer for the sub? The units I'm finding seem to be used to trim out an external mount rather than add depth to an internal mount as in TNA. Thank you!
Iv'e been tinkering with this the past few days as well. Searching Amazon you can find a few options (ABS or MDF) and there is a few that have some that have a recessed opening. But, I too was having a hard time figuring out what to get and if they would work with the OEM speaker
I am also changing the speaker - so it is throwing all kinds of issues my way..
On the TNA = the main hole size is only 8 11/16". The Bolt hole circular diameter is approx 9 1/4". The mesh material is definetly stretched tight enough that it is pressing against the woofers rubber surround.
The dimensions of the new woofer I have definetly wont work just dropping in like the oem speaker. Kicker Comp C 10" = the distance just to the outer edge of the foam surround is 9 1/8" (9 1/4" max) and the bolt hole pattern is 9 7/8" and 10 5/8" max od of the mount.
I bought bolts long enough to "possibly" mount the speaker from the outside/underside. >Still not sure which way I will go..
I haven't opened the sub chamber yet and actually pulled the speaker. But here is what I ordered for now to see what I can make work.
(they do sell 1/2" abs per 1qty - but I wanted the 3/4" - just incase I decide to get creative. Was kinda scared of splitting/cracking the MDF flavor since the id of the ring is only 9 1/8" and the bolt hole pattern of the stock speaker is 9 1/4"). I will post pics once I tear it open. Parts might be here Saturday.
