Quoted from TheNoTrashCougar:You need to check the power connectors to your PD-LED boards. If these are flaky, it can cause the LEDs to do weird things and get stuck. Use crimp connectors with Trifurcon terminals and you will be all set.
Ok soi checked all the cables to the boards and there was one semi loose/unseated ribbon cable. But I can’t tell which one is the power cable. Does anyone have a pic or diagram of the specific power cable for the pd led boards?
