Quoted from DuffysArcade:That is awesome! Update us on the mechanical condition. Glad to see no holes in the cardboard anyway!
Update on #116...
I've had it set up for a couple of days and have been playing and tinkering with it. I've got about 40 plays on it so far.
The good - It arrived with zero shipping damage. Nothing was knocked loose during shipping, game booted up and played right away. TNA is even better than I remember it. The last time I played one was at Zapcon 6 or 7, and I only had a chance to play it a few times. It made quite the impression back then. Glad I went with butter, pretty damn sexy! Worth the wait.
The meh - Mine came with 2 plumb bobs, one in the leg box and one stapled next to the coin box. There was a small piece of wood block in the head laying in there loose. Like some others, the rear playfield glass channel isn't aligned perfect. It seems to sag a bit in the middle, but after having the glass out a few times it's much easier to re-install than it was the first time. My right gate needed an adjustment, it was allowing the ball to roll under it in the closed position, simple tweak and it's working as it should. The spinner bracket was bent slightly up, but the spinner still functioned. It's been bent back to level and rips better now. The lower slings are touching the rubbers, but this doesn't seem to be impeding the switches from making contact and firing the sling when touched.
The brow-raising - There is no thread-sert for the head bolt... Anywhere. It's not in the hole and not laying anywhere in the cabinet. There is a speaker hum/static sound in the speakers in attract mode. I've turned down the volume on the back of the monitor, and it doesn't seem to have an effect on the hum. I have not adjusted the amp at all yet. Not an issue during play, but mildly annoying if the machine is left on. I've got a strange issue with my ball save counter digits. I think I saw something similar posted, and I'll have to do some digging here. All the segments work, however when counting down the center segment of the left digit does not light for "2" or "3" and the top left segment of the same digit does not light for "0". Yet those segments light for other numbers.
Nothing really majorly bad with this one... Yet. Hopefully it stays that way. TNA CE is my second NIB pin. My first was AC/DC Luci back in 2014. It had much worse QC issues right out of the box, bad enough I had Stern send me a new playfield, which was like pulling teeth to get done. Luci was an awesome pin to own, but TNA is already outshining Luci. Thanks for your hard work, Scott and crew! I feel lucky with this one after reading so many issues that others have had out of the box. I hope you guys can get yours fixed and flipping soon!
