(Topic ID: 195784)
Total Nuclear Annihilation Club...Welcome to the future!
By Pinballlew
2 years ago
  • 6,971 posts
  • 507 Pinsiders participating
  • Latest reply 22 hours ago by TheNoTrashCougar
  • Topic is favorited by 201 Pinsiders
There have been 1,099 images uploaded to this topic. (View topic image gallery).
22 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 6971 posts in this topic. You are on page 138 of 140.
#6851 41 days ago
Quoted from alexred:
I removed the bottom drop target from the playfield first to replace with clear. After removing the middle, I was able to replace that one and the top one with it still attached to the playfield. I used all existing holes and screws to mount the new LEDS. The top 2 with the existing standoffs work really well. For the bottom, I used the screw from the insert led that was nearby. It was the most difficult to get to sit right. It kept wanting to press into the drop target hole. A longer screw with standoff would be ideal to use instead. I hate c-clips! I have never been able to remove without something going flying, especially when they are spring loaded. Fortunately, the large speaker magnet right below catches most things that fly down. Great mod. Now there is one spare LED control to find a use for!
That final LED is maybe destined to get asigned for control in association with the Cooling Fan Mod!
Hopefuly!
#6852 41 days ago
Joined the club today... simple question
I set mine up ... playing great.
Incline is at 7.4 (not sure I totally trust the digital level)
Anyway what is recommended between 6-7 like everything else ? What is everyone else playing on ?
#6853 41 days ago
Quoted from jbigdoggf:
6.5
#6854 41 days ago
Just checked mine, it is at 6.3 degrees by my digital levels.
Also have planned out the windows I am going to cut into the pink protectors, to allow some of the the lock lane feature colours and light show to come through. Since there is alot of green involved, I'm hoping it will improve the look as the game is being played.
I wanted to avoid a full length slot so that the ability of the protectors to do their job is still there in part.
Interested to compare the green. Although I think it is going to be a case of they're both great! ... personal preference. Clear has it's strong points as well, especially with the new drops!
#6855 41 days ago
So it's done. Masked up the protector and marked it out...
I took a bit of care and it took some time, but the result I think has been worth it!!
So that now the lit green drops can be seen. The green came out dark and off colour in this close up clip, I think it's just the camera copping too many close up danesi lumens or something Lol...
Then I put the recording device up to film a test game.... which unexpectedly went fairly well
It was a satisfying game, even with the bits I was asleep at the wheel Haha, usualy don't get so lucky with the camera on either.... but the battery went low after about 10 minutes and .... wtf?? 10 MINUTES? Lol
Only missed about the last 60 seconds before I ultimately failed
I need to get an actual camera... they've been hader to get for a good price with what's been going on...
#6856 41 days ago
Moved my TNA to my son's house yesterday for him to enjoy and make a little room at my place. Holy cow. I forgot how heavy that game is !
Anybody know what's the actual weight of TNA ?
#6857 41 days ago
Quoted from NoQuarters:
I checked Google earth and Grafton has excessive gravity last week.
#6858 41 days ago
Quoted from razorsedge:
Hopefuly!
Agreed- you’ll have to post your setup. The fan I got is a little small and spins way too fast. But I’m working on something a bit more like you have shown in your post. If you get something put together please post it.
#6859 40 days ago
Hey guys anyone had an issue with lights sticking on a colour? I thought it was a one off but happened again recently, not sure if it is a hardware or code issue as happened both times ending a multiball. The lights stay lit the same colour no matter what happens in game until I turn it off and on again, once the machine reboots the lights are fine.
The lights not stuck all behave as normal.
#6860 40 days ago
Quoted from iEatHands:
Sounds like the same issue I had about 6 months ago. First link is the issue I had, and the second link is Scott's solution. It's a little foggy, but I'm pretty sure I reseated the cables in the head that Scott mentioned and that resolved the issue for me.
https://pinside.com/pinball/forum/topic/total-nuclear-annihilation-cluball-welcome/page/121#post-5314527
https://pinside.com/pinball/forum/topic/total-nuclear-annihilation-cluball-welcome/page/121#post-5315657
#6861 40 days ago
Quoted from THEFOZ:
Thanks - I’ll eventually fix it - just was wondering what it was for and why the coil was still working.
I recently thought my flipper was screwing up during play, but every time I checked it it would work. Except in some furious multiball- then sometimes it would not flip, and when the ball hit the raised flipper, it would collapse. Looked under the PF and that wire was broken off.
TL;DR: The wire was off, but the effect was subtle.
Don C.
#6862 39 days ago
Quoted from THEFOZ:
I set up a cooling fan I had laying around to do some very crude testing, check out what speeds I could get the thing to operate smoothly at. It's a bit larger than would fit, but to get an idea.
That's a 12v fan running on 4.5 volts pulsed 50% about 3hz ... then continuous 4.5v at the end.
There's a smaller unit on the way, so I'll wait to mess with that a bit when it gets here.
#6863 39 days ago
I see now what Scott means about holding off so as to impliment a friendly kit for the lit drops. The single RGBs aren't an easy simple screw in mount job.
Just gonna throw this out there -- on the janky R&M whitewood, I installed the drop LEDs with a 100% 'easy simple screw mount' - tiny rubber ring on the screw (all the R&M leds have these, not sure TNA does) - hold the LED board at a 45 degree angle behind the drop right next to the hole, drive the screw in on an angle. Done.
You really want a pretty good upward angle so the top of the drop isn't dark.
#6864 39 days ago
Quoted from epthegeek:
Do you have a picture?
#6865 39 days ago
Doing my best here. Janky is a rats nest. Pics: Left Target from the center, Right target from the center, then left target from the outside edge. LEDs are off in the picture - the glow you see is GI from above the PF.
7BA84E42-A8A8-45C4-B3D7-AA279D0701D3 (resized).jpegAC31C551-91F1-4C87-A5F2-A8850C5499D1 (resized).jpegE08E3D9E-E2AF-4F00-B650-E96D265BA712 (resized).jpeg
#6866 39 days ago
Awesome. Thanks!
#6867 38 days ago
So having some sound issues that started last night.
Loud buzzing/tone and static. Wasn't sure how to embed a short video, so it's on google drive...
Video here:
https://drive.google.com/file/d/1ap6-zHoKZmXaTYiUoeyrnHOUmte0CGc5/view?usp=sharing
#6868 38 days ago
Quoted from chrisnack:
Video here:
Check your sound amp in the bottom of your cabinet. Specifically the output wire (standard headphone jack). Wiggle it around and see if the sound changes. In my case, I had to disassemble the amp and fix a cold solder joint on the output. This wasn't anything to do with Spookys quality, but the manufacturer of the amp itself. I've had perfect sound since fixing that cold solder joint months ago.
#6869 38 days ago
Quoted from Jakers:
I was thinking it was something loose with the amp, I’m blaming the stronger shaker with the new code
#6870 37 days ago
Had problems with the sound since day 1 - when playing the sound starts distorting then goes totally bananas and the game has to be turned off.
i did actually report this to spooky at the time (few years back now) and they very kindly and quickly sent me a new speaker as i thought that was the problem.
Re-seating the speaker cables sorted it out a few times, but just recently (yes after the new code ) it went again, and half the sound is now out on the amp (temporarily i've wired left and right to the same output). Pretty sure this is all down to the shaker motor, i'm going to get a very similar if not the same amp replacement and put it in the back box i think, cable extensions to the sub.
#6871 37 days ago
Quoted from yyyyyikes:
The extra shaker, they're well overated imho. Cause more trouble than they're worth to boot. Mine's gathering dust on the shelf. The standard 12" shaker that is in there does a perfectly marvelous job on it's own!
#6872 36 days ago
Recently joined the club... I love this game.
Question do you have a pad of black foam under your left scoop ?
I can hit this shot but ball never drops left or right flipper what seems to be right on the money.
Only way it drops is coming out of reactor or a floater that rolls in there.
Wondering if it’s something that was added by previous owner and why.
#6873 36 days ago
They would have added it to try and make the ball go in the scoop better. The scoop is notorious for rejects. I always just fire the ball up the left orbit into the reactor when possible, and let it drop in from above...
#6874 36 days ago
Quoted from tomdotcom:
Thank you
#6875 34 days ago
I broke some of my you tube trying to do some editing nonsense... I reuploaded the clip ...
#6876 27 days ago
Has anybody ordered the custom armor from Spooky?
http://shop.spookypinball.com/Total-Nuclear-Annihilation-Armor-Kit-_p_40.html
I’m interested, but I’m not sold on the side rail or speaker grill design. I think I like the factory design better, but I do like the color.
#6877 27 days ago
Quoted from Pinbaltz:
I had no idea this was a thing. I’m not a big fan. It is hard to beat the standard armor!
#6878 27 days ago
I agree the triangle design is iconic, and "TOTAL NUCLEAR ANNIHILATION" down the side is plain badass, and sets it off.
I'm also a fan of the paralel rail look on the game, Bally style curved end.
#6879 26 days ago
Also, here's rough measurements of what I hacked together to mount Drop RGBs:
I like this approach a good bit better than just diagonal screws. Have you posted the STL file somewhere? If not, I can remodel it in a few minutes, using your dimensions. Are you happy with the LED placement/ angle using these? Thanks.
#6880 26 days ago
I see now what Scott means about holding off so as to impliment a friendly kit for the lit drops. The single RGBs aren't an easy simple screw in mount job. Something was going to be needed so I just finished whipping these babies up at work from some scrap ABS:
razorsedge - those RGB mounts look good. Did you hand-make those, or did you 3D print those with ABS? If printed, would you mind sharing the .STL file?
#6881 26 days ago
Ah, looking closer at them, it does look more like machined than 3D print. I think I'll try modeling them this evening and will post the file.
#6882 26 days ago
Quoted from herg:
That would be amazing herg - thank you so much. I can print them here at home, but my modeling skills are still...uh...fledgling.
They looked machined/cut to me as well, but I figured it was worth the ask.
#6883 26 days ago
Quoted from joelbob:
I bet it looks better in person.
#6884 26 days ago
Quoted from fnosm:
I'd maybe be down for the color on the original hardware, but I don't like the new design much at all.
#6885 26 days ago
I also wonder if this finish is available on the standard armour pattern?
Quoted from EightBitWhit:
Quoted from herg:
Yeah correct, cut from stock and finished by hand. All just work with 1mm cutoff wheel on grinder, and drilling. Made by the dimensions shown. Took me 20 minutes at work as a foreigney lol.
It's Great that you guys are sorting a print file for this. I'm too behind the times! Lol
I'm happy with the angle. Go too much more and I was getting concerned hard target hits may catch the dropping target on the PCB. Also with too much more angle, the clamping principle/design employed becomes less and less effective, weaker, and less firmly grips the PCB. It relies on the slot being shallower than the width of the PCB, so that the PCB is clamped against the playfield. One concern might be, if this clamping directly against playfield allows fatigue to affect the board too much, then some cushioning between playfield and PCB might be needed. The dome of the LED hangs completely over the edge line of the drop hole, and points upward at about 20 degrees, seems to shed light pretty evenly over the target. It refracts well. See pics and videos, although things always seem to look a little different in real life. My answer is, I am very happy.
#6886 26 days ago
OK, STL file is posted to Thingiverse.
https://www.thingiverse.com/thing:4461423
Dimensions are tweaked slightly for printing, but it still has the playfield clamping, etc.
I printed them on their side to make the thin piece stronger. The first two were looking great. The third one, the screw broke off while installing it. Yes, a steel screw sheared off while driving it about 1/4" into wood.
#6887 25 days ago
I've got a weird issue with extra ball being put into the autoshooter lane very occasionally, and giving me a random gratis 2 ball multiball (I know, I will take any edge I can get when playing this unforgiving machine).
Then today, a game finished, the machine is going through it's reset (releasing the balls from the drop target traps etc, no flipper power) and it starts pushing balls into the shooter lane and autofiring them. At one stage I had 3 balls in the shooter lane.
Any suggestions as to where to start looking ? Switch or loose wire somehow earthing the trough kickout coil or something completely different ?
And of course it happens on the day when I have got friends coming round in a few hours for some friendly competition!
#6888 25 days ago
Quoted from jaybeedee:
OK, so I think it is somehow connected to the switch on the bottom Drop Target when it is up. When I powered on the machine with that target up, the Trough Kickout was continously firing (with a delay). When I dropped the target the Tough Kickout worked as expected. When I started playing, as soon as I got two balls locked and the drop target up, the Kickout began firing again. The micro switch seems to be switching properly. Is there another switch or an opto in there which tells the machine that a ball has been trapped, and to release a new ball ?
#6889 25 days ago
There is an opto for each ball position. If one of those is not working reliably can cause all kinds of funny business. Doesn't match the symptoms I had with a flaky bottom lock opto tx though, but could be some similar combination. I had ball lock problems, phantom multiball in gameplay, but in attract mode just constantly cycled dropping targets to clear the ball it thought was there (but wasnt there), this is also why multiball would start randomly during gameplay. I think you have a different issue than this, cant help definitively I'm afraid.
#6890 25 days ago
So Switch test showed the Ball Jam Opto switching away while nothing should have been happening (no balls in the machine). I have played around with the IDC connector - one of the grounds seemed pretty loose. Now to see what happens, but first of all I think I blew a fuse while testing so now to find the fuses. I'll just look up the manual.... Oops, work in progress. Grrrrr
#6891 25 days ago
Hi kingpingames, is it a T4A fuse for the right flipper. trough kickout circuit ? (4A slo blo?)
#6892 25 days ago
When inspecting IDC connectors, check the wire is fully punched down into the back of the connector. I have had this fault cause intermittent problems before, where the wire is not fully punched in. I just got a tool and pushed it in to its proper place.
#6893 25 days ago
Does single LED test work in the latest code for all the shoot again segments? I have a couple that aren't lighting, but they do work in game. I didn't notice this until after installing the new fancy shoot again board.
I also have something weird going on with the right RGB. It's like the blue is sometimes on when it shouldn't be, off when it should be. White looks greenish. Red looks purple, etc. ...but not all the time. I'm trying to come up with a plan to test, maybe by swapping in the old shoot again board and connecting separate RGB boards. The intermittent nature makes it hard, though.
#6894 25 days ago
Quoted from herg:
The single LED test works fine for all 3 of my drops. They are the bottom 3 on the list a few hundred presses down. Lol
#6895 25 days ago
My drops are fine. It's the 7-segment shoot again display that I'm working on now.
Yes, pressing down "a few hundred" times to get to the bottom of the list is tedious, I agree.
#6896 25 days ago
Quoted from herg:
Sorry, Lol yeah of course shoot again display
Drops on the brain
Yep testing segments here they All light one by one, but flash slowly, if you go too fast you miss some. Not in order either, a bit mixed (half of right then left then rest of right), also a couple that seem to be unassigned. Also the shoot again lights test below those, work and cycle their colours fine.
The green segments seem to be on only part of the time during the single testing. Only showing one or two of the states through the colour cycle I would suspect (non RGB).
#6897 25 days ago
Quoted from herg:
Did the connectors get installed the right way around? . I have no idea the effect this would have?
#6898 25 days ago
Ah, the two unassigned ones fooled me. When I write down which one is lit, all of them do. 18 segments in the menu, 16 LEDs in the display. That all makes sense now. Thank you.
The only thing I still need to investigate is the right RGB. That's feeling like a marginally bad LED to me.
#6899 25 days ago
Absolutely brilliant, herg - thank you so much. I'll print these and give them a go.
#6900 25 days ago
Quoted from herg:
I printed them on their side to make the thin piece stronger. The first two were looking great. The third one, the screw broke off while installing it. Yes, a steel screw sheared off while driving it about 1/4" into wood. [quoted image][quoted image]
Appreciate you sharing your design razorsedge - it'll help big-time with the install.
$ 49.95
Pin Stadium Pinball LEDs
$ 265.00
$ 11.95
Pin Monk
$ 17.50
