Hi, I'm a TOTAL NOVICE and I opened up my '69 Bally machine for the first time yesterday. My left flipper is lagging behind when I press the button, and I noticed that the contacts seem "messy" in comparison to the right button contacts, which work like a charm when I press the flipper buttons; [open/close]. Also there are so many more pieces of metal contact strips on the left side; it's a much simpler layout on the right side; can I remove some of the metal, or maybe remove one of the spacers below so that they come into contact better? or perhaps I need a new set of metal strip contacts because one of them is bent & they may be worn out but I don't know what this kit is called if I order a replacement, can you tell me the tech name for these pieces? The flipper worked better when I tightened the screws, so I that seems to be the problem; but it's still not up to par.
Thanks for your help!
