Quoted from wayout440:If you have not done so, I would suggest swapping P2 cable inputs pins 1 & 3 to the aux power supply board. If the problem remains the backbox speakers dead, then you definitely have a problem with that board. If the backbox speakers work and the cab speaker stops working, then the problem is upstream at the sound board.
I did that, & still no sound from the top speakers & an awful screeching type noise on the bottom.
Speakers are confirmed good via ohm test (also they are new, from a new stern game I removed them from), all wiring has continuity to the back of the aux power supply board pins, & I've replaced every 3403 ic on all 3 of the boards. Still having same issue.
Any chance a bad rom could cause this?
I burned some new roms for the aux sound board despite multiple attempts & using different chips I couldn't get AROM1 to verify. Wrote ok but fails verification. AROM2 didn't have that problem.
