I have a Frankenstein that has started to give me an issue. When I flip the right flipper which also activates the top right third flipper. The problem is the top right flipper stays activated when releasing the right flipper button. It eventually goes down but not immediately like it should and occasionally stays up a long time. I did check the leaf switch and cleaned it. Appears to be making contact fine as it should. I am also in the process of ordering and replacing the coil for the upper right flipper hoping that will fix the problem. But is there anything else I should check or any other issue that may be causing it? Anyone else have this issue on msf or any other game with a third flipper. Thanks for the help.
