(Topic ID: 351422)
Tommy sound and dmd issues
By Don44
5 months ago
  • 7 posts
  • 3 Pinsiders participating
  • Latest reply 5 months ago by Don44
#1 5 months ago
It has a regular dmd , and a pinsound board. When I flip the flippers or a coil fires, the sound cuts out. The display occasionally has signs of low voltage and has frozen up at times. It has a rotten dog power supply and a aftermarket PPB board as well. Is there a better power supply out there to handle the pin sound board or any other suggestions?
#2 5 months ago
Anybody have any opinions on the X pin power supply?
#3 5 months ago
display cutting out or freezing could be ribbon cable, but I'd look to replacing the red and black wire plug that brings power to the DMD controller board.
Replace the pins on the board, and use crimp-and-stuff trifurcon terminals in the plug. It's only a three pin plug with two wires.
It used to be that this was THE problem with larger plasma displays like Baywatch, but lately I've seen this be a problem with the smaller displays.
Improve your power distribution, and see if that helps with the display problem.
I dunno about the pinsound issue.
DMD 'showing signs of low voltage'. Does this mean that you have letters that the top line of dots seem dim? If so, while that could be the display power supply board, it's quite likely that your DMD plasma display glass is bad. Dim at the top, particularly when the game is first turned on before it 'warms up', is a very typical sign that you need a new display.
#4 5 months ago
I tried swapping in another display board and a different display. I think my main concern is when I flip both flippers, and the sound temporarily cuts out. I think it’s being caused by low-voltage when both coils are firing. would I be better off with an X pin power supply then the rotten dog power supply? Would a color display use significantly less voltage and make a difference with the pinsound board?
#5 5 months ago
I see that pinsound makes a data east power booster. I ordered it so I will see if that helps before I proceed. It said in the description that it will eliminate the sound cutting out when both flippers are flipped. Fingers crossed for the $30 fix.
#6 5 months ago
Quoted from Don44:
Hopefully the cable from PinSound will fix the sound cut out issues. A colorDMD does take some of the load off of the power supply board.
I got a DE JP a few weeks ago and it had a Rottendog power supply board installed. It's had no issues supplying power but it has a tremendous amount of 12V ripple compared to the XPin power supply. That results in a LOT of LOUD speaker buzz.
Installed an XPin power supply board last night. The build quality of the XPin is far superior to the Rottendog. The Xpin 12V ripple is far less than the Rottendog and that equates into FAR less speaker buzz. Add in the White North buzz buster and it's almost silent now, as good as they get without PinSound.
Will never purchase a Rottendog product unless no other option is available.
https://pinside.com/pinball/forum/topic/data-east-pinball-club/page/60#post-8027646
Does your Tommy still have the stock speakers or upgraded PinSound speakers? I have a Neo+ coming in this week for the JP. It has the stock speakers in it but thinking of getting some new ones as they tend to dryrot over time.
#7 5 months ago
The power booster cable from pinsound, resolved my issue. I had had the pinsound in there for a few years without an issue until recently. It has flipper Fidelity speakers. It sounds great with The Who music playing. I don’t have any hum at all. As I recall it did before I put the pin sound in there. Will that buzz Buster work on Stern White star games like T3? As far as the display goes, I think it was a separate issue that has not happened again after reseating the ribbon cables
€ 27.50
Pin-Decals
$ 45.95
Filament Printing
$ 18.50
Playfield - Plastics
TheDudeMods
$ 45.00
Professor Pinball
$ 39.00
Arcade Upkeep
$ 24.95
$ 18.95
Mitchell Lighting
TheDudeMods
$ 28.00
$ 54.99
€ 25.00
Pin-Decals
$ 16.95
