G'day Pinsiders!
Love the information everyone shares on here! This is my first post, and I am hoping somebody has come across a similar issue to mine.
I am sorting through some issues on a Tommy the who pinball, and one problem that I have not yet resolved, is with the mirror continuously running up and down.
I have done the following checks,
- switch test/ both up and down show up as working correctly.
-I have looked at the contacts on the relay under the Playfield and reflowed the solder on this board
- I have tested the tip122 transistor at location Q25 on the CPU tested ok if an in circuit check is accurate?
The mirror starts running as soon as the machine is powered on, could the relay be the wrong type? Or is there something else I can test that causes this to be constantly powered?
Any help would be greatly appreciated.
Thank you
