(Topic ID: 231771)
Tomcat F14 cool wiring pic needed
By Barakawins1
4 months ago
  • 7 posts
  • 2 Pinsiders participating
  • Latest reply 4 months ago by Barakawins1
#1 4 months ago
Got this Tomcat and found wiring not attached. This coil is found al the far left side of the playfield. If you lift the playfield it’s at the bottom left. Can someone send a pic of how the wires attach? Here’s a pic of what o have. Thanks in advance
#2 4 months ago
The manual says that blue/black wire goes to the lower divertor coil. It is off for a reason, most likely a shorted transistor. The red/white wires just need to be insulated with a piece of heat shrink.
#3 4 months ago
I'm trying to figure out which lugs the red/white and blue/black wires attach to
#4 4 months ago
Quoted from Barakawins1:
Red/white wires do not connect to anything, but need to be insulated.
The blue/black wire needs to be soldered the the coil lug that doesn't have a wire on it.
You should test Q-79 on the cpu as it is most likely shorted.
#5 4 months ago
Got it so just install a wire nut on the red and white wires right?
#6 4 months ago
That would be fine.
#7 4 months ago
Thanks for that info.
$ 50.00
$ 5.00
Metal-Mods
$ 36.99
