(Topic ID: 133772)
Tomcat F-14 Flasher 5 not working
By piratewoo
7 years ago
  • 9 posts
  • 4 Pinsiders participating
  • Latest reply 7 years ago by Schwaggs
#1 7 years ago
I need some help (obviously since I'm posting here). I have all the flashers working except Flasher 5 (middle lamp in the attached picture). I can see that the wire comes from a driver board to the lamp and then goes to another lamp at the back of the playfield (they both flash together and currently neither are flashing). I don't see a loose connection and I'm not sure what to test. Can someone offer some suggestions? I have included a picture of the lamps at the top of the playfield and the driver board underneath (the White/Green is the one that seems to be the issue). I did note that there isn't a wire connecting to ground on that side of the driver board but I have compared with others and that doesn't seem to be abnormal.
#2 7 years ago
looks like your missing one of the warming resistors no ?
#3 7 years ago
Single ground is OK as you suspected.
The warming resistor is actually still there (330 ohm, 7W - the physically smaller one is warming).
The voltage dropping resistor is missing. You need a 5 ohm, 10W resistor put back in the open spot.
Part number RC10W-5 at GPE www.greatplainselectronics.com
If you want to stock up on the warming resistors, they are part RC7W-330
#4 7 years ago
Wow! Talk about missing the forest for the trees! I was looking for a loose wire and didn't notice the missing resistor (well, it's not missing anymore, I found it at the back of the machine with other old scary things). I've got some replacements on order so thanks very much! I'll let you know how things work out.
#5 7 years ago
Yeah, very often the resistors heat up and melt right off the board falling to the bottom of the cabinet.
#6 7 years ago
Very common on this machine for the resistors to come lose. This is the textbook example of a picture is worth 1000 words!
#7 7 years ago
Quoted from piratewoo:
Maybe it's still good !
You can easily check it with a DMM.
#8 7 years ago
Thanks guys, especially Schwaggs. Replaced the missing resistor and the flashers are now working fine! Now to tackle the top lights!
#9 7 years ago
Congrats on the fix! Glad it was an easy one!
Men
Other
$ 54.99
Shooter rods
$ 52.99
Pinball Shark
Shooter rods
Protection
$ 12.00
3,300
Edgewater, MD
$ 19.99
Gweem's Mods
Sound/Speakers
2,600
Lodi, OH
This page was printed from https://pinside.com/pinball/forum/topic/tomcat-f-14-flasher-5-not-working and we tried optimising it for printing. Some page elements may have been deliberately hidden.
