I have been fighting this thing for weeks if not months, done research until my ears saw color, and need some guidance here. The short and sweet:
- F-14 Tomcat (first and only pin so far)
- Rottendog board in nice condition
- Pop Bumper/ Ramp switches column is out (I Believe grn/ylw)
- Disconnected 1JP8 and 1JP10 connectors from board. Jumped all affected pins in switch test, all register when jumped as intended).
- Checked continuity as best I could from the wires in the playfield to each pin on the harness of the connectors at the board (while disconnected)
- Checked the continuity best I could between each of the wires down the line.
- I would think transistor on the board, but jumping the pins works.
- I would think short in the wiring, but I can't seem to find any.
- coming off of the 3 ramp switched under the playfield, there is a small board with 3 diodes connected. For the LIFE of me, I could never figure out where these are mentioned in a diagram, but know they are directly in the line. These have been replaced.
Am I missing something? I could go down the line and check every other diode by disconnecting one end and DMMing but that seems like a hassle. Would one butt diode even cause all of this? I'm at a loss and just need some guidance as to where to try next.
