I can play a game or two and it will work fine , then it will not kick out a ball after locking ball one -but usually after locking ball two. It won't "find" it either.
AFter tilting it and restarting, it will spit out one of the two balls, but
It will say "missing ball" - but it's in the subway to the trap door.
I went into the Trap door test and dropped the remaining 3 balls and it then it spit out all 4.
However, upon subsequent tests when dropping in the 4 balls , sometimes it went through
the sequence of switches 44,43,42,41 in correct order of open and then closed and spit out all 4, but
sometimes it started with switch 43,42,41 instead.
sometimes it would kick out all 4 balls, but sometimes only 3 .
I'm not sure what the problem is - is there a flaky switch or something in the switch matrix screwed up?
I'm terrible at understanding the switch matrix...
any help is appreciated. The game is unplayable as it stands...
thanks
M
