Quoted from schudel5:Why not try it and see? I've had to weld parts before that came apart and they're still doing fine.
I'm into the weld! I just wanted to confirm with the universe that this would be ok to move forward on. Still new here and already had regret-sies on "fixes" I didn't research well.
Quoted from dq13:I'm into the weld! I just wanted to confirm with the universe that this would be ok to move forward on. Still new here and already had regret-sies on "fixes" I didn't research well.
Nobody here is going to care if you fix this by welding it. You'll probably get kudos if it works. If we could fix Stern coil stops by welding them, we probably would.
Quoted from dq13:Any reason not to weld them together?
If the collar is thicker than the bracket. You may burn the bracket before a good weld is possible.
On MM troll carriages. I brazed them. Worked great.
This page was printed from https://pinside.com/pinball/forum/topic/tom-trap-door-assembly-to-weld-or-not-to-weld and we tried optimising it for printing. Some page elements may have been deliberately hidden.
