Hi All,
The pinball gods have invaded my Theater of Magic and adjusted the pin so that the Trap Door fires the balls right down the drain every time I have multi ball.
Is it an easy fix?
Regards,
Steve
Hi All,
Is it an easy fix?
Regards,
Steve
First make sure the game is level. After that you will probably have to adjust the bracket where the kicker is mounted to change the angle of where it strikes the ball. You should be able to bend it slightly with a little force. Also make sure no part of that assembly came loose which would alter how it strikes the ball.
This page was printed from https://pinside.com/pinball/forum/topic/tom-trap-door-aim and we tried optimising it for printing. Some page elements may have been deliberately hidden.
