I am getting a “check switch 45 left outlane” error on my Theatre of Magic. I adjusted the potentiometer and in switch test mode the LED lights up but the switch stays open when I run a ball over the switch. I traded the right and left eddy switches (and not using the original cables and switches, only the eddy board) and the same thing happens. With the now right outlane switch (previously the left lane) the LED turns on with a ball over the switch but does not register. The switch does not register as closed. What am I missing? Do I need to replaced the eddy switch? Interestingly, when I reboot I no longer get a "check switch" error code for the right out lane.
