Hi guys:
This happened after installing playfield LEDs but surely that is a coincidence?
When the machine announces 'multiball' it doesn't kick the balls out of the basement, as it should. The machine just sits there but here is the strange part. After a number of seconds, it does a ball search (as it should) and after a number more seconds, a second ball search and then a third ball search. Then it announces 'multiball' again and, this time, it does kick the balls out as it should.
Obviously, there are no balls stuck otherwise it wouldn't necessarily kick the balls out when it announces 'multiball' for the second time.
It's always the same. No balls kick out on the first multiball announcement but they do kick out on the second multiball announcement.
I did check the ball trough optos (not knowing what else to try) and they are working as they should.
The machine worked fine until I changed the inserts to LEDs today but how can doing that cause this to happen?
Any help appreciated.
Roger
