Dear Lloyd
Our resident pinball guru Lloyd Olsen answers Pinside readers questions!
Monday October 17th 2016
Hi Lloyd:
My ToM right drain magnet is not working.
The transistor that controls the magnet is Q64 and is not blown.
I did a continuity test from the PCB to the magnet and all OK, so no broken wires. I also checked that the plugs in question were correctly connected to the PCB
The magnet is brand new and tests out the same as the left drain magnet (working OK) on my DMM.
In case it was connected somehow, I tested all the eddy sensor boards that turn on the magnets in play and they test out fine on the switch test. I also disconnected the right drain eddy board, to be sure, but nothing helps.
When I test the right drain magnet in the solenoid test, it won’t pulse but the lights dim for a fraction of a second, as if the magnet was pulsing, just like when testing the magnets that are working.
I was going to use my DMM to test the appropriate PCB pin for 50V but i’m not sure where the black DMM lead goes. I have never tested voltage before.
I can’t think of anything else to try.
Your help and suggestions would be very much appreciated.
Thanks so much, Lloyd.
Santini
This page was printed from https://pinside.com/pinball/forum/topic/tom-magnet-blues and we tried optimising it for printing. Some page elements may have been deliberately hidden.
