I read about adjusting the eddy sensor on the trunk and performed that operation on both of the hocus pocus magnets as they did not appear to be working. One of them was finicky about the light going off during the adjustment, but eventually the both did. I wanted to test them so I hit the hocus pocus target and ran the ball over the magnet (on the playfield) and nothing happened. I noticed if I shorted the potentiometer on the sensor boards it would trigger. Is the magnet itself the actual sensor as well? Is there something I am missing when trying to test this?
As a follow-up I noticed that the front-left of the trunk (facing it) has a dead spot right on the corner of the trunk. I think the metal post there should have a rubber on it (mine does not) so that might be the solution but even after adjusting the eddy sensor this exists. Is that normal?
