So I just picked up a TOM and a couple of fuses are blown. One fuse is on the driver board F104, I'll get to that in a bit, but I also noticed one of the fuses F904 on the Fliptronic 2 board is blown.
My reading of the manual on page 3-14 shows the Flipper coil circuits. The F904 sits between the Bridge rectifier and the Red-Blue wires from J907 pins 4-5. This should power the lower left Flipper Coil. When I completely remove F904 my flipper still works??? Only if I remove F902 does my left flipper stop working.
Is the manual backwards? Did somebody miss-wire my cabinet?
Thanks in advance.
