There is another topic regarding something similar, but I don’t want to hijack that thread.
I have just acquired a routed TOM. I have fixed a couple of things; next on my list was to get the magic trunk to detect hits. I adjusted the eddy potentiometer(s), and viola trunk hits (whew! I don’t need to replace the eddy board).
I played a game to see how it went. I don’t recall the sequence, but I think I locked to start multiball, and something malfunctioned. Long story short, the coil in the Ball Feeder Assembly (A-19934) stopped working. It was working before, but no longer.
The Fliptronics F903 fuse was blown. I thought that was odd, but discovered that’s how it’s designed. Since it was working before, I decided to replace the fuse and power it back on. Bad things happened.
Flippers both flipped, and the DMD showed a random pattern. I powered down and discovered F903, and also the Solenoid Secondary fuse F112, on the Power Driver Board, was blown. Also, the CPU board LED D19 and D20 never came on (this explains the DMD pattern).
I powered off, disconnected the Fliptronics board from the bus, and powered back on. The CPU board LEDs displayed properly (D20 blinking).
I don’t want to blow a bunch of fuses trying to diagnose. I don’t currently have a work bench with a power supply to do the bench testing of the Fliptronics board (http://www.pinwiki.com/wiki/index.php?title=Leon_Borre_WPC_Fliptronics_board_repair). Any suggestions? If it was just the one circuit, I could disconnect the all of the coils. But even with the fuse blown, and the Fliptronics ribbon cable connected, the CPU LEDs D19 and D20 remain off (and the DMD shows random pattern).
Is there any “typical” problem with the Fliptronics II board? Any key words to search on to help narrow down the issue? If I am going to need to do the bench test, any recommended power supplies?
Thx
