Ok fair - before the DMD issue, a ball got stuck, under the play field, between the trunk and the trap door. Lifted the play field to get the ball back to the trunk. The DMD issue occurred after I reset the play field and booted the game back up.
When the DMD looked bonkers and didn’t show correctly, the game could still be played and the flippers worked.
Turned the system off, removed and cleaned the DMD Control board and fuses. Problem persisted. Found that thread above (I had the PAGE ERROR B (1) 0 15 error) and reseated the ribbon in those 4 locations. Restarted system and the screen was back to normal hut the flippers don’t work and there is no sound either when you try to press the flipper buttons.
