Transferring from the listserv. Seems while I've been away from the hobby, a great deal of traffic has moved over here. So I'll try to see if you guys can help me out.
Hi Pin tech wizards:
Just finished fully rebuilding a Theatre of Magic. It LOOKS unbelievable now. But still doesn't work as intended. Generally works, but there are some gremlins flying around that are driving me crazy.
Here goes: Starts up, runs great. Plays fast as designed. Tested every switch, light, coil, and magnet. All work in test. All work in play... until she gets confused. Sometimes this can take a long time, and sometimes very soon. Usually long enough for you to think its fixed because of whatever I just did... to then sorely disappoint.
We are running TOM 1.2 and just did a full teardown of the machine.
When things get flaky, the trunk stops being wiling to move, or will be kept in the wrong state. Sometimes also - the trap door will keep one ball in the subway with or without the trunk flaking out. Finally the "open trap door" light on the ramp only will open the trap door half the time.
The only aberration I can find is that +18v on TP8 wanders from 14.7 and 18V. A wider range than I would expect. So I replaced the caps and bridge for the 18V circuit. (BR1). Didn't do BR2 as I had used my other spare for a stereo repair. But the 5V is solid. After the replacement, the voltage still wanders and the flakyness still happens.
Additional detail, is I can then go into test mode and find the trunk in an error position. But if I then do trunk test, I'm able to move it to a new phase with the buttons and once in a new position, the error clears.
Not sure what to try next. Any ideas on what could cause this kind of flakiness?
Thx
Skarv
Ps. Did Clay's recommended jumpers to the board while I did the bridge/caps.
