Looking for help on a TOM I brought home yesterday. Machine worked great at Sellers.
Set it up this morning. Vacuumed the cabinet and dusted down some of the wire harnesses in the cabinet (didn’t touch any wires under the Playfield)
Turned machine on. Everything seemed fine for 30 seconds. Walked away to put away vacuum cleaner when I returned the machine automatically fired three balls into the shooter lane and the color dmd went out. I shut the machine off and a little smoke started billowing from behind coin door. Lifted the Playfield...but couldn’t identify where smoke came from.
Checked fuses. F116 (+12V secondary) was blown. Replaced it. Turned machine on. Looked like dmd was going to light up, but then went out again. F116 blew again. Disconnected Dmd completely. Put new fuse in F116. Turned machine on watching the fuse, and fuse immediately blew again.
Down to my last 3amp fuse. Don’t want to do the insane thing again and blow that without isolating problem. Never tried to troubleshoot without a DMD to help me with tests.
Any suggestions on how to spot the problem?
