Hi pbm3
I think You should buy manual and schema --- then showing snippets of schema of "interesting areas" . ipdb has nothing to Toledo / Valencia.
I agree with You (post-5): Every given ball starts with "one Bonus for free" - a feature I do not like, makes the pin more complicated.
I believe Your pin has an "Bonus-Relay" - when You loose a ball - ball rolls into Outhole - Bonus-Relay is activated - lets the Bonus-Unit step down - Bonus-Relay DROPS OUT , Outhole-Relay pulls-in, steps the Bonus-Ladder up one step, kicks the ball over to the Shooter-Alley.
So I would have a close look at the Bonus-Unit - last step stepping to ZERO - I believe ONE Switch OPENS and at the same time: A Make-and-Brake-Switch is moved.
The Bonus-Relay must pull-in so Bonus-Ladder is stepped down - but in the end it MUST DROP-OUT.
I can show it on Wms Little Chief, my JPG, red Numbers:
Ball rolls into Outhole, closes red-1, IMPORTANT: red-2 is active (there ARE Bonus on the Ladder. Red-3 pulls-in, establishes Self-HOld-Current (red-4) --- after a long time Bonus-Counter gets to Zero, so red-5 will open.
In the meantime theough red-6, 7, 8, 9: Bonus-Ladder is stepped down. Reaching Position-Zero: red-5 opens, (therefore red-11 closes again) - Switch red-2-red-10 moves to red-10, red-12 gets active --- then red-13 and red-14 and red-15 (Bonus step-up), also red-13 and red-16 and red-17.
Maybe You are lucky and find a "switch to open" and an "Make and Brake Switch to move" - the two switches that are moved when the Bpnus-Ladder is steppd from Pos-1 to Pos-Zero.
Anyway - I advice (my belief: EVERY pin should have manual and schema): Buy the paper-stuff. Greetings Rolf
