I have a Zaccaria Time Machine that I picked up as a fresh from the container re-import.
Lucky for me it booted up and played fine with a good cleaning and shop job.
It had no electronic or mechanical problems at all, and played fine for quite a while.
But..............
I had a pop bumper switch stick closed, causing the bumper to fire continuously.
Before I realized what was going on and shut the game off, it did some damage.
It burned up the pop bumper coil, so I replaced that with the equivalent Williams coil per Dave Gersic's website.
The 3 amp under playfield fuse was burnt, so I replaced that.
Game boots up fine, goes into attract correctly, and will start and play a game.
All the switches, lamps, and sound work fine.
There are several coils not firing in test or in game. They are:
06, right target bank,
08, left pop bumper
11, right pop bumper
21, motor relay (I think)
22, center pop bumper
Everything else seems to be fine.
I do see a burned spot on the interface (driver) board in the area near R117, Q13, and C32
Seems to me like I need to send the interface board to someone with a clue for repairs.
Am I missing anything?
Anyone here do Zaccaria board repairs? If not, anyone know if Dave Gersic is still doing repairs?
Any help is appreciated.
