Quoted from Skybug:I used diluted Simple Green, sprayed on a cloth, then wiped on the PF (as that's what I thought it said here to do). Then I used ME with alcohol (step 2). They each got some dirt off, the alcohol more so. I skipped step 3, Novus 2, as I'm nervous about using a product for plastics on something that's not plastic. Then I put carnauba wax on it.
Ok thats fine as there is a fine line between just enough or Ut Ohh!
Better on the safe side.
Quoted from Skybug:BTW I tried the wax - just for a second - on my flaking paint on my backbox. It took off more flecks of paint. How can I keep the paint from flaking any more, like is there a spray wax or something?
Other than a repaint it may be something to live with ,you may want to see if you can treat it like a flaking backglass that is maybe a satin clear coat over it to hold it down, used to painting cars/trucks so wood is a little different as it has a substrate that changes at a rate different than metal (ie: wood and humidity dont get along)so the paint on wood cant keep up with the wood changing at a different rate.
Maybe someone clear coated over a backbox/cabinet and can lead you in the right direction?
For me I will repaint come spring/summer for some pins I have,1st some tracings, get a close color match,repair dings scratches,sand,feather ,mask ,paint.treat it like everthing else I painted (time and patience)and it should be fine.
