What
A complete assets replacement of Stern's TMNT using assets from the 1987 animated series.
Why
I have absolutely no problems with the video assets that Stern put in TMNT. In fact, I think they did an outstanding job. However, there's just no replacing the old school coolness of the original series. Now that my 4-year-old daughter is watching every episode with me to relive the magic, I really wanted to see her face when the pinball machine showed the 1987 series on it. Plus, I think it will make a lot of pinball enthusiasts out there happy.
Updates
* Using 1.57 code now with fixed images
Current version (1.57)
* Pro: https://drive.google.com/file/d/1UC84jKz8EsGCOiihFslbWPYYipwo7iFl/view?usp=drive_link
* Premium / LE: https://drive.google.com/file/d/1UB48HgUUGMtXWKTO_pmp4-yyRX-UL_QY/view?usp=drive_link
Previous version (1.56)
* Pro: https://drive.google.com/file/d/1TzvAaTRflZpe5h-gh1Ke_g_oi4r41hh0/view?usp=drive_link
* Premium / LE: https://drive.google.com/file/d/1TuXNXQbPBnlwUGZIhM4xXdr3EZShlqmF/view?usp=drive_link
What you need
* 16gb class 10 SD card (note that the original SD card is 8gb and you should keep it safe anyway)
** This is the one I use (SanDisk Ultra 16GB Class 10 SDHC UHS-I Memory Card up to 80MB/s (SDSDUNC-016G-GN6IN) https://smile.amazon.com/SanDisk-Class-UHS-I-Memory-SDSDUNC-016G-GN6IN/dp/B0143RTB1E/ref=sr_1_1
* SD card reader/writer
** This is the one I use (Anker 2-in-1 USB 3.0 SD Card Reader for SDXC, SDHC, SD, MMC, RS-MMC, Micro SDXC, Micro SD, Micro SDHC Card and UHS-I Cards)
https://smile.amazon.com/Anker-Portable-Reader-RS-MMC-Micro/dp/B006T9B6R2/ref=sr_1_3
* Pinball Browser (un-licensed version works fine).
How to install
First after downloading from the link, extract the file if necessary (.zip extraction).
Then follow the instructions here:
Do not use Balena Etcher to write to the SD card! I have had a high failure rate using this program! You will know if it fails if you have any in-game restarts while playing (or more likely when booting). Use Pinball Browser to write to the SD card. Follow the instructions on my YouTube video linked above.
Validation errors
If you have any validation errors, swap to the official Stern code and play a game or two - this should clear the errors out.
FAQ
* Can I switch between this SD card and my original Stern SD card if they have different versions? Yes, you might see a node-board update when you go between different versions, but it will work fine.
* If I want to save all of my settings and high scores on my card before re-flashing it, can I do that? Yes, refer to USB drive backup instructions from Stern (in the pinball menu UTIL-> Save / Load)
* Should I use this with Insider Connect? Works on my machine. That being said, there are validation checks within the software. I don't know what Stern would do with that information, but you can always swap to your Stern SD card to use online if you're worried.
Donations?
No, but I'll take your upvotes.
Limitations / Omissions
* The pizza eating contest animation as you’re smashing the button I left as is.
* The ‘match’ videos remained as is (I turn ’match’ off anyway).
* I did not do the 3 videos (intro, loop and end) for Cowabunga. If you get there, let me know and I will use clips of your choosing!
* Sometimes, there are no real episodes that correspond to the episodes on the pinball machine, so I had to be creative. For example: Slash fighting the turtles in Dimension X.
What it looks like
IMG_20200903_081138 (resized).jpgIMG_20200903_081151 (resized).jpgIMG_20200903_081218 (resized).jpgIMG_20200903_081234 (resized).jpgIMG_20200903_081311 (resized).jpgIMG_20200903_081348 (resized).jpgIMG_20200903_081354 (resized).jpgIMG_20200903_081518 (resized).jpgIMG_20200903_081610 (resized).jpgIMG_20200903_081658 (resized).jpgIMG_20200903_081659 (resized).jpgIMG_20200903_081739 (resized).jpgIMG_20200903_081749 (resized).jpgIMG_20200903_081851 (resized).jpgIMG_20200903_081952 (resized).jpgIMG_20200903_082053 (resized).jpgIMG_20200903_082226 (resized).jpg
