Quoted from richierich85:
Ok. tooling is made so i now have connection to get these ramps reproduced. So if you want one im willing to pay and get made for you and get shipped to you. please understand i spent alot of money to get two ramps for myseld, i dont make these they are made through a molding company. They are 3mm thick, approx 98% accute in size and shape, they work well. I will point out they is minor plastic flaws on the curves as to vaccum form tight spots where and issue, in saying this, its just the look does not affect ball run what so ever. If you interested let me know so i can do up numbers for a bulk order. they will be $250USD plus shipping. i am making $80 off each one bit i have to trim out myself so thats my time to do so. i spent the big bucks on tooling to help others with damaged ramps. PM me if your interested. thanks all[quoted image][quoted image][quoted image][quoted image][quoted image]
Hey richierich85 ,
Kudos to you for getting new tooling made to reproduce new ramps! Well done and much appreciated by me and many, I'm sure. I was going to PM you but had a couple questions I thought might be better to post for others to read and get your thoughts on as well. Just looking at the pictures, I'm trying to get an impression of how similar or different the new ramp is in comparison to the old one. From the pics, it looks like the turn round at the top right is a little shorter. Could just be the pic, or maybe it doesn't turn around quite as much but doesn't matter?
Is the 3mm wall thickness thicker than the original? Just curious if that's about the same as original or beefier? On my ramp, I have a metal guardrail that was made to patch a crack in the turnaround, but honestly feels like a good permanent feature I might add to a new ramp like this one. I added a couple on the left side walls ramps too, that had also cracked. Was just wondering if you think the new ramps you made were any more robust in these areas or are they mostly a reproduction of the original design?
Still very interested and thanks for the new repro's! Just was curious on a few things.
Leebo
