(Topic ID: 162727)
Tips on easily removing .156/.100 pins from connectors?
By westofrome
  • 34 posts
  • 15 Pinsiders participating
  • Latest reply 3 years ago by vid1900
    #1 3 years ago
    Tried both the official Molex tool from GPE and a jeweler's screwdriver and while I can do it, it seems way harder than it should be.
    When I'm removing a pin from a connector in the head, the connector is usually attached to a wiring harness, so I need one hand to hold the connector firmly and another to press down on the locking tab with the tool, and another to pull out the pin. So three hands.
    Do folks typically free the harness to the point that they can rest the connector flat on a firm surface to free one hand?
    THERE HAS TO BE A BETTER WAY
    #2 3 years ago
    Let's see pictures of the connectors in question please.
    #3 3 years ago
    Insert the removal tool, hold the end in the cup/palm of your hand, and hold the connector housing with your fingers. Tug on the wire with your other hand.
    Or, hold the removal tool with 2 fingers and a thumb, and the connector housing with your remaining two fingers. Tug on the wire with your other hand.
    #4 3 years ago
    If you plan on crimping a new connector to the wire, there is no need to be gentle with removing the old connector from the housing. I'm not suggesting a hammer, but all I use is a small screwdriver and press hard on the securing tab....hard enough to simply push it out of the way... then connector comes right out.
    #5 3 years ago
    Quoted from Freeplay40:
    Exactly.
    If you are replacing the contact, just press the locking tab in with an Awl and it slides out with no resistance at all.
    Do this with the connector pulled off of the board/male pins.
    #6 3 years ago
    Thanks guys - definitely not worried about the old connector pin, more about damaging the connector housing if I'm trying to press and slide with the same motion with the tool.
    #7 3 years ago
    Quoted from westofrome:
    I only use the tool if I'm keeping the crimped connector end (like someone installed them in the incorrect order).
    Scratch Awl is much faster.
    Poke all the tabs down at once, and slide all the connectors smoothly out.
    Take a pic before you begin just for a sanity check. You can chew up a lot of time having to go back to the schematics.
    #9 3 years ago
    I use a small flat head. I usually find a place in the head or cabinet nearby to set the connector on. Then with one hand push in the tab with a screwdriver and the other hand pulls the wire out. Takes a bit of practice and then you get good at it without mangling the housing.
    If you are repinning the entire plug, the only connector housings worth reusing are the really long ones in a bally game that you can't find anymore. They are cheap enough i usually just use a new housing to save the step of pulling the contacts out of the original housing.
    #10 3 years ago
    Quoted from barakandl:
    Do you know specifically which molex connectors are unobtanium?
    #11 3 years ago
    I can't find any larger than about 14 or 16 pins i think its. Bally used some 25's, 28s in .100" and up to 20 in 1.56".
    #12 3 years ago
    Use 2. Cut one so that put together they have the right number of circuits. Lightly sand the uncut edge and the matching edge of the other connector. Mix a little epoxy and apply a thin coat on both the sanded faces. Stick them together and line them up straight. Let it cure overnight on some cardboard or something. Light pressure on either end is preferred. Wipe off any squeezed-out epoxy with a water damp paper towel. The next day trim off the excess with a box blade.
    Order some keying pins.
    Which brings up the question: what do you use for a keying pin if you don't have any in your pocket?
    #13 3 years ago
    I've had good luck using an Xacto knife to push the little tab down and slide the connector out. The tip of the blade digs in just enough to get a good bite without doing any damage to the connector. Just be sure to wear safety glasses in case the tip were to break off. I worked with a guy who lost an eye when a piece of the razor blade he was using as a scraper broke off.
    #14 3 years ago
    Quoted from cody_chunn:
    Order a bag of keys whenever you order the housings, because some brands don't fit other brands.
    But if you are totally stuck on location, use your mini diags to cut the old housing down each side, and reuse the old key.
    #15 3 years ago
    I've always had terrible luck getting epoxy to stick to Nylon anything.
    If the old nylon housing is still dimensionally good (it can have a scorch mark, but not deformed), I'll reuse it and simply put the date of rebuilding on the face. Color is a better match than new bright white anyway.
    #16 3 years ago
    The longer ones (like the 20s).
    Sometimes a hoard of them will pop up, but it's iffy.
    Reusing the old nylon housing is sometimes the only solution.
    Remember to date it after you rebuild it, so the next owner does not assume it's 40 years old.....
    #18 3 years ago
    A little off topic but I figure to throw it on here while we are talking pin removal.
    So here it is. Those barrel pins which ed and others sell removal tool for also have one female pin. What is the trick there?
    Just one of lingering questions I've had.
    THANKS
    #19 3 years ago
    Quoted from CNKay:
    THANKS
    For .062 and .093 pins I've found those spring-loaded removal tools work equally well for male and female pins - are you saying the female pins are giving you trouble when you try to remove them using the tool?
    #20 3 years ago
    Yeah the tool did not seem to work / fit at all. If i am remembering correctly?
    #21 3 years ago
    Quoted from CNKay:
    Sure you had the correct size?? Sometimes you have to push pretty hard on the round pin extractors to get it to slide overtop of the locking tab.
    #22 3 years ago
    Quoted from CNKay:
    You have to sometimes "do a little circle" with the tool to get it to release.
    #23 3 years ago
    Quoted from CNKay:
    You have to make sure that the outside "tube" of the tool is seated all the way down before you push on the handle to drive the pin out.
    Chris Hibler - CARGPB #31
    http://ChrisHiblerPinball.com/contact/
    #24 3 years ago
    Like others have noted, I use a small flat blade screwdriver. An awl is equally effective.
    Just punch the pin "tang" down and pull 'em out.
    #25 3 years ago
    I've gotten pretty good at removing and replacing them. I do them one at at time and when I take one out, I repin it, and put it into the eh new connector right away so that it's easy to remember where they all go. Also, this is me every time after re-pinning a bunch of connectors:
    #26 3 years ago
    Yes, roll the pin extractor in a circle around the base of the female pin to push in the tangs while lightly pushing in the plunger. Once you figure it out, they become easy.
    #27 3 years ago
    #28 3 years ago
    Quoted from SealClubber:
    Also, while doing this - push a bit on the wire -into- the connector from behind. This will slightly separate the contacts tangs from the plastic body by a hair and tends to make it easier to push the extraction tool over the tangs (less chance for them to bind up on the backside of the connector cavity).
    #29 3 years ago
    I regularly stock up to 20 pin sizes for 0.156" and can get them up to 24 pins.
    For 0.1" connectors, I have sizes up to 25 pins but have run out of 28s. Went through 15,000 of these (where the heck did they all go?!?!) and can't get this size anylonger. Even tried to get them custom made but no dice.
    #30 3 years ago
    Quoted from G-P-E:
    Damn. That's too bad. Thanks for trying though Ed. Always appreciated.
    #31 3 years ago
    Wow, 15,000...where the heck did they all go?
    #32 3 years ago
    Quoted from ForceFlow:
    they made a lot of early bally ss games
    #33 3 years ago
    i have been using 20 pin connectors from a couple head wiring harnesses i had spare.
    #34 3 years ago
    No doubt, lol.
    But remember, you can simply reuse the old housing.
    No need to throw out a bunch of rare housings when only the contacts need replacing.....
    $ 10,900.00
    RMV Sales
    $ 76.95
    $ 12,500.00
    $ 44.00
    $ 66.95
    $ 4.49
    $ 23.25
    The MOD Couple
    $ 99.99
    € 4.99
    Multigame
    $ 150.00
    $ 7.95
    Various Novelties
    Pinball Wheezer
    Lighting - Under Cabinet
    $ 38.00
    $ 149.00
    $ 160.00
    Id Rather Play Pinball
    $ 29.95
    $ 11.95
