I'm not quite sure what you mean--the terminology you're using isn't quite right. Are you talking about the wooden playfield rails on the edges of the playfield? The plastic channels on the top edges of the cabinet that hold the glass? The long metal siderails on the cabinet?
Quoted from GPS:Appear to be primarily held in place with staples any and all tips appreciated
For removing staples, look for furniture staple remover/puller tool. I've used Berry's removers, although the more modern puller looks interesting.
If you're removing metal siderails, putty knife to separate the siderail from the cab slightly, then use vampliers to pull the nails out. Depending on how proud the nail heads are, you might be able to skip the putty knife and just pull the nail heads.
