I have to drill out the lock in the backbox of a Stern Stars. Any tips would be appreciated. What size bit, etc..
Hi Hi-Fi,
You may want to search for 'lost key' on the Pinside forum and you will get plenty of hits. Here is one example:
https://pinside.com/pinball/forum/topic/lost-keybackglass#post-2292389
Gord
easy peasy, just drill away. That's all I did and it spun or broke the piece in a matter of a minute or two. I've done it twice and had no issues either time.
There are a lot of ways to drill a lock, but I prefer this method of drilling the pins out. The guy in the video has a little trouble getting it to turn, but 95% of the time when I drill out the pins, the lock turns on the first try. I even taught a bunch of high school kids how to do it when I went and visited their shop class to pick up a pin.
Some people will say to drill the entire tumbler out, including the screw and tongue on the back of the lock, but you don't need to be that destructive.
Quoted from Wolfmarsh:There are a lot of ways to drill a lock, but I prefer this method of drilling the pins out. The guy in the video has a little trouble getting it to turn, but 95% of the time when I drill out the pins, the lock turns on the first try. I even taught a bunch of high school kids how to do it when I went and visited their shop class to pick up a pin.
» Vimeo video
I thought that was a SNL skit when the video started rolling. Pretty good info though.
Also put a towel down to catch any drill cuttings. If they ever found their way onto the playfield it would be an abrasive situation.
I like using a bit small enough to just fit in the slot first. Often it will back that screw out that holds the lever-piece on and the lock will still work if you find the key later. Then if I have to, graduate up bit sizes.
Have you thoughly checked inside the cabinet?
I have drilled locks only to find the key a day or so later
A nail in the corner?
Loose at the back of the game?
Quoted from Charliew65:On the backbox i usually just unscrew the 4 screws and the lock falls right out.
Too bad the OP's game isn't like that.
LTG : )™
Silly question but have you tried picking it? These locks weren't very secure to begin with, it usually takes me less than 20-30 seconds to get in to one. I don't use real lock picks, just my micro screwdrivers or a bent up old dental pick.
My friend was somehow able to jimmy it open. He could not repeat it but getting it once was all we needed. Thanks for all the advice though. I'm sure at some point I will have to drill one out.
I learned how to pick locks - kits are cheap, and when you pick a lock instead of ruining it, you never know what you find, like the key! (True story - the spare key was locked inside the head.)
Quoted from Billc479:I learned how to pick locks - kits are cheap, and when you pick a lock instead of ruining it, you never know what you find, like the key! (True story - the spare key was locked inside the head.)
How do you lock the thing without the key?
This page was printed from https://pinside.com/pinball/forum/topic/tips-for-drilling-out-a-lock-1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
