Pinwiki says the WPC lamp columns use a TIP42. My manuals say TIP102. I think this is a mistake on Wiki but I am no expert here. Aren't 42s PNP and 102s NPN and thus not-interchangeable?
you are correct. tip42 are PNP, 102 and 122 are NPN. Refer to the schematic and not the part layout or BOM whenever you are unsure of a part. Typographical errors exist in lots of these manuals, but almost 100% of the time the schematic is correct.
Lamp rows (Q83-Q90) are NPN darlington transistors TIP102
Lamp columns (Q91-Q98) are PNP darlington transistors TIP107
Both of my WPC schematics (1993 and WPC-S) say the rows are TIP102 (NPN) and the columns are TIP107 (PNP). I doubt such a basic error would have lasted through several editions of the schematics.
Which specific transistor number are you questioning?
Thanks SealClubber for bringing this up. That was a cut and paste error that I made. I'd copied that section from the System 11 section and missed that edit.
Cheers to you!
Chris Hibler - CARGPB #31
http://www.Team-EM.com
htt://webpages.charter.net/chibler/Pinball/index.htm
No problem, Thanks for clarifying. I wasn't sure if maybe people were using 42s in place of 102 or something.
In the sys 9 games, there is an error where the bom calls for a "2n3904 PNP" which made its way into sorcerer, comet, and space shuttle manuals. Obviously a 2n3904 is an N-channel transistor, but it can be misleading. But the schematics are correct on all 3.
You need a high gain NPN transistor for the matrix. The TIP102 and TIP122 both have a minimum gain of 1000, the -102 being a maximum of 20,000. Both are 100V Darlingtons. This means they use very little current to fully saturate.
The TIP42 is a PNP with a gain of 30. Even if you used a TIP47 which is an NPN, the gain would be insufficient.
If you have an issue with excessive load on the transistor and you have confirmed that it's not a shorted component causing it, you could always substitute a TIP142 in place of it, although the package is larger.
This page was printed from https://pinside.com/pinball/forum/topic/tip42-vs-tip102 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
