(Topic ID: 219412)
Time Warp boot-up error
By ScottK
5 years ago
  • 3 posts
  • 3 Pinsiders participating
  • Latest reply 5 years ago by Schwaggs
#1 5 years ago
Hi,
I have a Time Warp machine and for some reason, it seems to be stuck in the diagnostic mode, I keep seeing numbers in lower right counting up starting at
04 - 00 to 04 - 35 and it recycles. Any ideas? Thanks
#2 5 years ago
Sounds like it is fast scrolling through audit mode.
It could be coin door switch problems or a mpu problem that reads those switches. Is there corrosion on the MPU and has the battery holder been removed? The lower right battery terminal's through hole connected to ground can get ripped out and cause a similar symptom. Try unplugging the coin door connector diagnostic connector from the mpu and see if the scrolling stops.
#3 5 years ago
I agree with Andrew. Coin door connector enters the CPU board at J4 which is in the upper left corner of the CPU board. The second 4 pin connector in from the left across the top.
$ 130.00
KAHR.US Circuits
$ 9.95
$ 27.95
$ 170.00
Displays
Digipinball Shop
Tools
Pincoder Store
This page was printed from https://pinside.com/pinball/forum/topic/time-warp-boot-up-error and we tried optimising it for printing. Some page elements may have been deliberately hidden.
