I rarely like to admit defeat but I have to say I am pretty irritated with my twilight zone. I have clock problems and I have encountered clock problems before but not like this. Here is where I am at:
The clock did not work on the game when I got it although it had a new rotten dog board in it. I took the clock apart to access the optos on it and went into the test menu. Some of the opts were not working so I figured easy fix, swap it with a new board. Same result. So at this point I figured I rebuilt the clock wrong and took it back apart. Rebuilt the clock again, hooked it up with the playfield in the upright position from under the playfield, clock works great. Unplug everything and mount it on the topside, put the playfield down and turn the game on, clock error. SOB. Take the clock off again, second guess my assembly and do it all over yet again, install with playfield up works great, move on to the full install, drop the playfield down and clock error.
At this point I start checking all ribbon cables, the clock harness, all connections on the opto board, connections to cpu, basically double check all wires involved. No change. So I decide time to go to the shop, grab another clock from a tz that I know works. Swap it into the game with the playfield up from the underside of the game, clock works great. Install it on the topside, clock shows bad. Now if either of these clocks are installed on the topside and I raise the playfield up, they both work great then too. So there has to be something going on when the playfield is lowered that I just don't see. I have ensured that no harnesses are being pulled when the playfield goes down. The only thing I have not done yet is replace the opto board on the bottom of the playfield, maybe there is a cold soldier joint, replace the rom chip in the cpu or swap the cpu all together.
Some background:
I have rebuilt maybe 20 clocks over the years, I am not an expert but I am familiar with them.
I made sure the teeth are lined up as well as the line for the black gear.
Checked all continuity of the clock wiring harness. I also even swapped the harness with the second clock harness to see if it would make a difference and no change.
Have had switch test open with the playfield raised up, watched all switches and lowered the playfield, no switches activate or deactivate when the playfield gets lowered.
So if anyone has experienced this please let me know what I can do to remedy this issue. It is driving me nuts. Also if anyone can think of anything that I have overlooked please let me know. I did order a replacement board from INGO in germany and will have it hopefully soon.
Thanks for any help.
