Has anyone scanned the plastics on Time Fantasy?
some of my plastics are good and I can scan but I was hoping someone had a good scan of a complete set. There are tons of guides on how to make plastics at home. As far as full on professional repros that are exactly like the originals? From what I understand that would take some serious cash and the larger the run the cheaper it be. Before I try to make my own plastics I need good scans.
shlockdoc - can you post the scans?
Here are some scans (300dpi) of the plastics from my Time Fantasy pin.
The plastics are not the best (slightly warped and some scratches)
Also these scans do not include the Time Tube Plastic
nor the top left and top right archway plastics (too big to fit on scanner).
Also note that my left side plastic was cracked/split at the top end (2inches).
Thanks! I will scan what plastics I have as well. If anyone else can contribute that would be amazing
The scans of the upper left and right corner plastics are coming out poorly for me because my plastics are a tiny bit warped. I am going to place them between two pieces of playfield glass in back of my hot car and see if they will flatten out a bit. Hopefully then I can get a good scan to post. Looks like pinwiztom has already scanned all the rest so i will focus on those upper plastics.
I am thinking about improving the time tube design by making it two separate pieces so there is less stress on that piece.
I did not scan the time tube plastic yet,
for one it would be a bit of a hassle to remove it
and primarily it has the stress crack in the normal bend place.
This page was printed from https://pinside.com/pinball/forum/topic/time-fantasy-plastics and we tried optimising it for printing. Some page elements may have been deliberately hidden.
