I just got the game up and running a couple days ago, '78 playboy, and was playing fine. Last night a tilt issue arouse, when you push the start button, it does the start up music, resets the drop targets, does not kick the ball out of the out-hole and immediately lights up tilt. Like I said it was playing fine for the last two days, in switch test no switches are showing stuck on. In all the other examples I could find online with this issue normally the switch test would show something then leading you to suspect diode or the capacitor on the plumb bob tilt. In switch test if I manually close each tilt switch they register as closed so they appear to be working. Any suggestions to likely culprit? Thank you in advance for guidance.
