(Topic ID: 70593)
Thoughts on adding/removing playfield items to change game play.
By Jags
10 years ago
  • 14 posts
  • 9 Pinsiders participating
  • Latest reply 10 years ago by TaylorVA
    #1 10 years ago
    I've often thought of adding or removing certain playfield items so that it would change the game play of a pin. For example adding a small center post between the flippers on games that constantly send balls straight down the middle. Or removing a gate to change the ball flow. Or even adding a pop bumper or flipper to change the way the game plays.
    Although I have not done this sort of thing to any real pin I have experimented with doing this on a few different Pinmame pins. The results have worked out very well in some instances.
    Just wanted to hear some thoughts regarding this idea. Has anyone actually done this to their pin? Anyone else ever consider it? Would it be blasphemous or sacrilegious to do this to a pin?
    Let's start a discussion!!
    #2 10 years ago
    Personally any mods are fine as long as they are reversable (easily).
    If you find yourself in a funk with your pins why not try extra rubbers or added wires or plastic parts secured by current playfield parts. sounds like a groovy idea.
    #3 10 years ago
    Adding a center post to a game designed not to have one, is like putting training wheels on your dirtbike.
    #4 10 years ago
    Quoted from tomdotcom:
    Ok, What about removing the center post on a game that was designed with one so it would make it more challenging?
    #5 10 years ago
    pretty sure PAPA does that all the time for high-level tournaments.
    another cheater example: my local Op got a Harlem Globetrotters that someone put a post between the two left flippers to prevent getting double flipper bitched. He removed it first thing.
    #6 10 years ago
    Quoted from Jags:
    This is ok, yep
    #7 10 years ago
    I removed the control gate to iron hide on TFLE. Best thing I ever did to that game.
    #8 10 years ago
    Remove the ball. That'l change things
    #9 10 years ago
    Quoted from Eskaybee:
    Could you elaborate more on exactly what you did? Perhaps post some pics and explain how removing the control gate created better game play.
    #10 10 years ago
    Quoted from Jags:
    I don't own TFLE anymore, but removed the control gate from the IH mini pf makes it so the ball can't get trapped up there. Allows faster gameplay and makes playing the IH mode a challenge.
    #11 10 years ago
    I took the upper left orbit gate out of WPT, per the suggestion of the designer. Many others have done so as well.
    I also added a deflector to the POTD exit in LOTR. Even though Keefer maintains the random dropping ball design was intentional, I far prefer the smoother/faster flow and prevention of ugly bounces, playfield dings, broken plastics etc. to scoring a few inconsequential souls if the ball bounces into the shire.
    #12 10 years ago
    I'm all in favor of people altering games. It doesn't matter if you make the game easier or harder, as long as you find it to be more fun. For example, I did the post mod on my TZ. This prevents the ball from bouncing out of the rocket. To me, this makes the game much more enjoyable. I would, however, caution against performing any mods that do irreversible damage to the playfield (i.e. adding a post between the flippers). In the case of my TZ mod, the game can be easily reverted back to its original configuration.
    #13 10 years ago
    A flipper post is reve3rsible. There's just a tiny, insignificant hole there when removed.
    #14 10 years ago
    I removed the post and rubber ring in the pops of WH2O that keep the ball in the pops opposed to letting it go towards the right outlane. There is a switch over there that is impossible to hit with the rubber there so seems like the ring was just added to make the game a little less punishing out of the pops.
    This page was printed from https://pinside.com/pinball/forum/topic/thoughts-on-addingremoving-playfield-items-to-change-game-play and we tried optimising it for printing. Some page elements may have been deliberately hidden.
