Quoted from SLCpunk2113:Is anyone having an issue with their diverter becoming misaligned? What is supposed to keep it straight? All I can figure is spring tension unless mine had a part break off.
Post a pic...welds have been known to fail on it.
Quoted from scootss:Post a pic...welds have been known to fail on it.
You can see it’s misaligned. Am I missing a part on this mech?
Quoted from SLCpunk2113:You can see it’s misaligned. Am I missing a part on this mech?
I'm not in front of mine, but based on some pics I just checked...looks like it is all there.
Seems like maybe a lockwasher underneath the brass screw might help, but that's just a blind observation. Also not in front of mine at the moment.
Edit: Check out the image gallery in the owner's thread for some other pictures. The diverter had issues early on with the welds not being strong/numerous enough, and the upshot of that is that there are lots of pictures of the diverter in the club image gallery. For example, page 2 of the gallery has several (notably none with any lockwasher hardware, though it might still be helpful to add one).
Edit 2: The manual shows the hardware used in the assembly in section 5.42, might help to compare the diagram to your machine to see if anything noteworthy is missing.
https://sternpinball.com/wp-content/uploads/2022/05/Mandalorian_LE_Pre_web.pdf
Quoted from freeplay3:Just curious about value on a Mando topper. I have one on my game along with shooter and side rails. Was thinking of taking them off and putting an ad up. What is a fair value on all 3 items as a set? Thanks in advance for any help.
Supply of the topper is still limited so pricing is in your favor. At least MSRP, I would guess.
Shooter and Armor are pretty available still so you’d probably have to go 75-80% on MSRP for those.
Quoted from freeplay3:I have one on my game along with shooter and side rails. Was thinking of taking them off and putting an ad up.
You may not want to remove your siderails if you drilled additional holes that do not align with factory. What are your thoughts on topper-I am not a topper guy-just curious.
Quoted from pinmister:You may not want to remove your siderails if you drilled additional holes that do not align with factory. What are your thoughts on topper-I am not a topper guy-just curious.
The topper is way way way overrated. I sprung the $2k for it and it was not worth it. It has incredible potential, but as it is currently coded, it does very little other than show static pictures.
Quoted from 1963BSARGS:The topper is way way way overrated. I sprung the $2k for it and it was not worth it. It has incredible potential, but as it is currently coded, it does very little other than show static pictures.
Agreed
I bought my topper for 2k shipped nib. This was right after the run but the guy started at 2800 and probably was lucky I bought it at 2k. If you get msrp then that would be awesome. I’d sell mine at msrp in a second
This page was printed from https://pinside.com/pinball/forum/topic/this-is-the-way-stern-mandalorian-pinball/page/153 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
