(Topic ID: 129972)
This ain't your grandma's GI!
By lyonsden
  • 60 posts
  • 28 Pinsiders participating
  • Latest reply 4 years ago by lyonsden
  • Topic is favorited by 19 Pinsiders
There are 60 posts in this topic. You are on page 2 of 2.
#51 4 years ago
So, if I wanted a particular LED sequence to occur say, when a eject saucer kicked out, I would need the pinuindo to be tied in to the coil trigger outputs from the Solenoid Driver Board on an early Bally?
So anything triggered from a transistor is able to be 'sensed' and controlled by the Pinuindo (like SCRs that control feature lamps as well)? Or is it just the coil drivers?
Sounds like it is just the task of making a series of piggyback adaptors for the early Bally boardsets and then working on programming?
-scott
#52 4 years ago
Quoted from Lonzo:
As a general rule, I don't like colored GI because it changes the look of the Artwork. But I have to admit that I lke this idea. I like how the machine has the normal look and then the colors change to match the gameplay. And they change fast enough to give you a shot of color and then back to normal.
Nice job. I might look into this.
Thanks Lonzo. I agree about color bombing a playfield ruining both the artwork and my ability to see the ball. One thing that I do with these setups is to keep the spot lights white and permanently on. That allows the game to "pop" when general GI changes color, but keeps *some* white light on the the main part of the playfield so I don't lose track of the ball. Still, when the Zues scoring effects that I made are running in Tron, it still messes with my ability to track the ball. The combination of a two-pulse light on-off-on-off-on with the ramp effect just screws with my eyes. But, it looks so damn cool that I keep it.
#53 4 years ago
Quoted from drscottsmith:
-scott
You have it down -- anything controlled by a transistor can be monitored. Coils, flashers (I'm not sure what SCRs are). And yes, it is just about making molex/IDC adaptors to piggyback of plugs from the power-driver board that drives those devices and running them to the pinduino.
#54 4 years ago
Thanks! Looking forward to the project!
-scott
#55 4 years ago
-scott
The kits will come plug and play. You do not need to build the harness. I just need to know what generation wpc, stern, sega, de, capcom ect...
Your guy's work is in the programming, not the wiring. I will probably give a discount if you post your code for everyone.
Cheers
Chris
#56 4 years ago
Quoted from Rock914:
Cheers
Chris
Awesome to hear! Building the harnesses was the biggest PITA for me. Also, I like the idea of discounts for those that post code new games.
#57 4 years ago
I'm all over this. I've had Arduino's for a long time and done a few things with them in my home brewing setup, but was always looking for something to use them on for my pins. Already PM'd Rock, so hopefully I can join the fun.
#58 4 years ago
Quoted from datafry:
These boards are a blast if you like Arduino programming. Checking your game list, there are a couple that already have some code developed: https://github.com/elyons/professor_pinball_pinduino_sketches
#59 4 years ago
Fantastic, but it looks difficult to install.
#60 4 years ago
Quoted from SuperPinball:
I wrote up a set of DIY instructions: https://pinside.com/pinball/forum/topic/diy-ultimate-color-changing-gi-interactive-with-gameplay
Overall, it isn't too bad. Basically, unplug power to GI, take out old GI sockets, wrap them around existing cables to keep them out of the way (and zip tie in some places), install new addressable LED string, connect Pinduino, and have some fun. Programming the pinduino is easy: https://www.arduino.cc/en/Guide/HomePage
$ 229.99
PinballBulbs
$ 58.00
$ 26.95
$ 50.00
