ok, new info, partly due to my own stupidity. I had the pins on the 7402 chip in the wrong order in my head. I had them 1-7 down the correct side then from pin 1 end 8-14 down the other side instead of the correct down and back, so any info I gave you before in regards to the chips was incorrect.
I have no continuity to grnd on pin 7 of 1J19, except during coil test, then all the time. I get Low on pin 12 of U45 all the time, and nothing on pin 13. On Q75 I have nothing at B, whereas on the other 2 transistors next to it I have Low. I have nothing at Q74 on any leg. This is all with 1J19 disconnected. But with 1J18 connected.
Here is the info from before correct with the proper pins...As just checked with the new components installed.
U38@pin 39 HIGH, U48 pins 1-6 Low, 7 High, 8 Low, 9-14 high, U45 1,3,4,6,7 Low, 2&5 High, 8,10,11,12 Low, 9 &14 High, Nothing at 13. Q74 Nothing, Q75 nothing at B, Low at C&E. For reference, Q76 B&E Low, C High, Q77 B&E Low. nothing at C.
During game mode, no continuity from pin 7 1J19 to Grnd, fuse in and 1j18 connected.
I am assuming the components I used were good, it was a Tip102, MPSA06, and the SN74LS02N. I verified good continuity after soldering in with my meter to make sure I made good connections. more so with Q75 and the damaged traces.
So what is my next assignment?
