New! Dark mode!
(Topic ID: 28281)
Theatre of Magic Trunk Problem - False Sneak Ball
By JAXPinball
8 years ago
  • 3 posts
  • 2 Pinsiders participating
  • Latest reply 8 years ago by JAXPinball
#1 8 years ago
Okay, I'm back.....
I just purchased a TOM that has problem with the trunk.
At the beginning of the game, the trunk will spin after hitting it twice and then the software activates the "Sneak Ball" routine and thinks that a ball is locked in the basement; however (note that the ball is still in play).
Besides this issue, I am assuming that this causing a false read on Multi-ball when there are only two balls locked in the basement. Multi-ball will flash on the PF and will one hears Multi-ball announced; however the two (2) balls that are locked stay locked below.
When I eventually get the third ball locked, then the switches fire and release all three (3) balls.
Any advice on what to look at first, second, etc. would be helpfull and greatly appreciated.
Respectfully,
Aaron
#2 8 years ago
Assuming the correct number of balls are in the machine it sounds like a switch issue. I would put the machine in switch levels test mode and look for any stuck switches. After that put it in switch test and test the optos.
#3 8 years ago
Thanks cal50... I will run the tests
$ 11.00
$ 19.99
PinballElectronics.com
$ 49.95
Pin Stadium Pinball Mods
$ 60.00
Whitewater pinball mods
