Have had this TOM for a bit. The trunk not spinning slowly degraded over time to not spinning at all. It was a simple reboot and it would spin again no problem. Now it just doesnt spin. Switch test I can spin the opto interrupter manually and see the switches activating for all 4 cube positions on the display just fine. Trunk test starts normal switch 56 closed rest open. If hit the +/1 get trunk motor error.
When you go into test menu I get check
Trough 3
Cube Pos 1
Cube Pos 2
Cube Pos 3
Trough 3 would probably be why it started kicking out balls randomly. Not sure why that is, will circle back to that after the trunk is fixed I guess. Fuse look good. Not sure what the deal is. Was working for months fine. Then it went to if you hit the trunk while spinning it would stop spinning and require a reboot. To not working at all. When I tested the motor things seemed to spin fine, no wierd noises, speed was consistent.
ideas? Need more info? let me know. Thanks in advance for assistance.
#theatre-of-magic
