Thanks for the kind words guys! I can help out for sure just send me a pm to discuss.
All back together, just waiting on cpu to power up and test run. Did a trunk light mod as well.
USER_SCOPED_TEMP_DATA_MSGR_PHOTO_FOR_UPLOAD_1597624046317_6700920927965571855 (resized).jpegUSER_SCOPED_TEMP_DATA_MSGR_PHOTO_FOR_UPLOAD_1597641451350_6700993929966153404 (resized).jpegUSER_SCOPED_TEMP_DATA_MSGR_PHOTO_FOR_UPLOAD_1597632622093_6700956897376731500 (resized).jpegUSER_SCOPED_TEMP_DATA_MSGR_PHOTO_FOR_UPLOAD_1597633631771_6700961132274646515 (resized).jpegQuoted from KJS:All back together, just waiting on cpu to power up and test run. Did a trunk light mod as well.[quoted image][quoted image][quoted image][quoted image]
WOW... that looks simply amazing!!!
Thankyou!
Got it powered up today, sorry for the poor quality phone video, bit dark and colours blown out.
Quoted from KJS:Thankyou!
You need OCDLED maybe to control the LEDs a bit.
With it. Its way better.
That speaker panel is amazing !
Are you selling this mod?
Quoted from pinballinreno:You need OCDLED maybe to control the LEDs a bit.
Agreed. The OCD board makes a huge difference.
Yes I have an ocd board here, but believe it or not its the phone camera doing that flickering! Not evident in real life. But I will look at it further for sure.
Quoted from KJS:Yes I have an ocd board here, but believe it or not its the phone camera doing that flickering! Not evident in real life. But I will look at it further for sure.
Its not the flickering.
Its not the phone.
Its the super harsh on and off flash typical of unregulated LEDs
Put the board in, its like night and day.
Get the GIOCD also, you wont regret it.
The alternate speaker panel is so much more better that original
the artwork complements the original translight and makes it complete and uniform
Quoted from weaverj:looks like the "protector" that fits over the right-side entrance of the big ramp.
Do you mean the ramp in back of the haunted basement entrance? I have both ramp protectors on there and they look different. I don’t see anything in any pics. Any other possibilities?
Mike V
Quoted from weaverj:[quoted image]
And I didn't even knew that protector existed. Now, what part number could it be so I can order one...anyone?
I have just had my Theatre of Magic Sound Board recapped to try and solve an issue with slightly scratchy sound. Caps C20 C21, C32, C41 C18, C19, C15 and C52 were all replaced. Unfortunately I now have a new problem with the sound cutting out completely after a few balls. This often happens when a ball launches and the sound just goes completely silent. If I switch off and switch on again the sound will come back for a few balls and goes again?
Any Idea's
I also noticed that the score increases 200 points on every press of the flipper buttons? Is this something I need to change in the settings or another problem?
I have managed to solve both issues. After reseating the ribbon cable for the third time the sound is no longer cutting out but I am missing the correct sounds when the Multiball is triggered?
I also solved the flipper button scoring which was down to the spinner switch triggering from the vibration, so a small adjustment solved that one
Unfortunaly I still have slightly scratchy sound, so any suggestions on what to try next?
Quoted from Andypc:I have managed to solve both issues. After reseating the ribbon cable for the third time the sound is no longer cutting out but I am missing the correct sounds when the Multiball is triggered?
google or search pinside for scratchy sound.
It involves a bit more than a simple recap of the board.
Chris hibbler is a good place to send your sound board.
Or upgrade to pinsound plus, the shaker is awesome!
I was a little skeptical about trying this, but followed the PinWiki advice to cut off the ceramic caps C37 and C45 and it worked. The difference is huge and it now sounds amazing. I hadn't seen many post with feedback on how well it worked, but I would highly recommend it to anyone with scratcy sound from a DCS Soundboard.
I recently joined the club. Hadn't had much opportunity to play TOM before purchasing. What a great game!
I have a question, though. In midnight magic, when I hit the magnet on the trunk, after catching the ball it typically releases it straight down the middle. The game gives another ball, so it's not too much of a problem, but it really disrupts the flow of the game when you hit the trunk over and over during midnight magic.
Is this normal? If not, where is the ball supposed to release? Any suggestions on how to fix?
Quoted from curban:I recently joined the club. Hadn't had much opportunity to play TOM before purchasing. What a great game!
Loosen and turn the mech or interrupter slightly so that the ball drops to the left flipper.
Check your level horizontally.
Quoted from pinballinreno:Loosen and turn the mech or interrupter slightly so that the ball drops to the left flipper.
Thanks. I’ll give it a shot.
Can someone talk more about the multiball crash mentioned in the v1.4 home rom Text file?
I was playing a 4 ball multiball the other day on my TOM v 1.4 Home rom machine and my whole Machine went dead Like the power got shut off and then rebooted Itself , wanted to know if this is what they are talking about as the crash in that text file or I had another issue, first time I ran into that, thanks!
Playfield level was good both in front and back.
So, I’m not really familiar with the machine or the trunk mechanism. It looks complex.
If I loosen the nuts on the board underneath the trunk that has the opto switches, there’s a little play...I pushed it as far counterclockwise that it would go —-I think this would cause the magnet to be rotated more towards the left flipper during midnight magic. Is this logical, or am I misunderstanding the purpose of the board and switches?
Results seem like it may have helped, it seems after first two trials that the balls consistently drop right onto the very tip of the left flipper...better, but not ideal.
I didn’t try doing the same with the 4 nuts holding the whole mech on the Playfield yet. I don’t have the right tools to get to them very easily.
Is there another way to adjust the positioning/rotation of the trunk? Did I misunderstand the recommendation?
Quoted from curban:Playfield level was good both in front and back.
No you got it right.
But some tools, loosen it, twist it hard to the left.
Quoted from Bravebluerx:Can someone talk more about the multiball crash mentioned in the v1.4 home rom Text file?
Sounds like a 5v reset problem on the driver board.
Probably 5v section needs to be rebuilt.
Quoted from pinballinreno:Sounds like a 5v reset problem on the driver board.
Thanks for the thought, it has a fairly new Rottendog power driver board
My Sound is cutting out again So this issue started while trying to solve another issue. I had scratchy sound that was eventually solved by removing caps C37 and C45 form the sound board.
Unfortunately I now have a new issue of the sound completely cutting out that I did not have before getting the sound board recapped? Caps C20 C21, C32, C41 C18, C19, C15 and C52 were all replaced. That didn't solve the scratchy sound, but introduced this new issue
The sound just cuts out completely after a few balls. This often happens when a ball launches into the shooter lane after losing a ball and the sound just goes completely silent. If I switch off and switch on again the sound will come back for a few balls and goes again?
I thought I had resolved this with the brand new ribbon cables, but apparently not. Any suggestions?
Quoted from Andypc:My Sound is cutting out again So this issue started while trying to solve another issue. I had scratchy sound that was eventually solved by removing caps C37 and C45 form the sound board.
Pinsound with shaker.
Completely changes the game.
I put a Pinsound in mine and it was a waste. Pinsound is great, but adds nothing to this game. There is not great music to really enhance. I did not use the shaker so can not comment on that.
I would go back and check all of the cap values and make sure all of the solider joints are good.
Quoted from Gohigh54:I put a Pinsound in mine and it was a waste. Pinsound is great, but adds nothing to this game. There is not great music to really enhance. I did not use the shaker so can not comment on that.
You are sadly missing out by not having the shaker.
Its amazing.
The audio will never blow you way as its just simple sounds for a pinball machine.
Too bad you didnt go all the way with it, you are almost there!
Enhanced audio is slightly better than the original, but the shaker is over the top.
Quoted from embryon:Hiw do you install a shaker and does the original home rom utilize it?
The pinsound shaker or "motion control system" is supported by the pinsound board itself.
They do a great job of implementation on shakers.
Unlike other shaker concepts, you dont have to do anything.
No programming, no hooking to flashers or motors.
No hours of creating a theme.
They did it for you.
Its pretty easy and a "turn key" all in one solution.
I like flipper fidelity speakers for ease of installation and documentation.
Its not the cheapest, but i think its the best.
Plus i like that i can customize the sounds a bit, if i want to.
I especially like adding start up sounds to games that dont have any.
Pinsound and a supported shaker has made my theater, funhouse and doctor who competitively modern and tons more fun.
Quoted from pinballinreno:The pinsound shaker or "motion control system" is supported by the pinsound board itself.
Pinsound and a supported shaker has made my theater who competitively modern and tons more fun.
Nice to know, but what surprise me is that they dont list the #TOM in their "Shaker packages already released" list. ( https://www.pinsound.org/motion-control/ )
Etienne
Is it possible to have the original sounds and music with pinsound. i.e. exactly the same as the original DCS soundboard? Can you install the board without upgrading the speakers?
Yes, you can use the original speakers. I upgraded my speakers and it changed the sound. The old sound card did not sound good with the new speakers. I added the Pinsound board hoping that it would sound better. I have a Tommy with Pinsound and it is awesome. ToM, not so much. Many on the music pins have new and remix Pinsound packages that are awesome. ToM uses the original sounds.
Can you buy say Tom shaker and put it on a Tz and simply get the coding from them like you can do with colordmd
Quoted from etien:Nice to know, but what surprise me is that they dont list the #TOM in their "Shaker packages already released" list. ( https://www.pinsound.org/motion-control/ )
Etienne
Under bally WPC DCS:
Quoted from embryon:Can you buy say Tom shaker and put it on a Tz and simply get the coding from them like you can do with colordmd
the shakers are encoded on the pinsound ROM.
So, you need the pinsound sound card
On the cheap side you would have to get a shaker system from maybe pinwoofer and program it yourself.
It takes many hours to get shakers just right, I have done it and took maybe 80-160 hours.
For that kind of time, I always get the pinsound now. They do as good a job as I could imagine.
Quoted from t_robertson:Hi all, I’m new to fixing machines so go easy on me. I recently replaced the original eddy boards with auto eddy boards (trunk plus 2 out lane magna saves). Trunk works well but I’m getting errors on switches 42 & 43. Any advice?
Loose or disconnected wire?
See if you can clear the error with a ball in switch test.
Just got a TOM and need to replace the THEATRE decals. Several of mine are in bad shape and missing large portions of each letter. The game came with a decal kit so I have them, what is a good way to remove what's left so I can put the new decals on? Need to replace one on a insert as well. The decals that came with it look like stickers to me and not water slide.
Issue number two is that I can't seem to get that ball to go all the way around if I hit the left orbit. It won't make it up the right wire form, it goes into the pops instead.
Love the game so far. Put comet sunlights in it and a led color dmd last night.
Quoted from subedriver:Just got a TOM and need to replace the THEATRE decals. Several of mine are in bad shape and missing large portions of each letter. The game came with a decal kit so I have them, what is a good way to remove what's left so I can put the new decals on? Need to replace one on a insert as well. The decals that came with it look like stickers to me and not water slide.
Can't help on the stickers, I bought a set from ebay when i got my TOM and I ultimately decided to leave the PF as is (I only had 2 inserts with minor wear). If anyone is interested in the stickers hit me up.
For the orbit shot. There is a gate that opens right in front of that right wireform. I believe hitting the left orbit switch will trigger it. My guess would be either that switch isnt registering, or something is wrong with that gate. I would start in switch test mode and see if the orbit switch works to start.
Hey Guys
Having a weird issue -
you know how when you're waiting to plunge, you can select the illusion for the skillshot using the flipper buttons? Mine cycles through them in a weird way. Some of the illusions can't be selected, and strangely, some of the magicianship lights (bottom 4 diamond shaped lights) are included in the cycle.
Haven't dug in at all yet, any ideas on where to start?
Machine seems to work really well other than this one quirk. It's a HUO machine that's very clean.
I have had this issue since changing to the home rom bit I think I changed back to 1.3 and it persisted so went back again to the home rom
I cannot get the trunk balk save to work. It did work pre rom change but since the change it doesn't matter which rom I use it won't function. I have balk save on and works and I turned trunk ball save on but no go. So if you hit the trunk with a Sdtm shot you get no ball save. The trunk reed switch works otherwise the modes wouldn't work.
Any ideas on what to look at?
Quoted from embryon:I have had this issue since changing to the home rom bit I think I changed back to 1.3 and it persisted so went back again to the home rom
Are you running 1.4H? I think they took the trunk ball save out, I forget. I am running Soren's custom rom (which is awesome!) https://pinside.com/pinball/forum/topic/new-theatre-of-magic-software-mod-version-2/page/2 it fixed my pet peeve (if the hocus pocus ball save doesnt work it gives you your ball back)
Quoted from arcadenerd925:Are you running 1.4H? I think they took the trunk ball save out, I forget. I am running Soren's custom rom (which is awesome!) https://pinside.com/pinball/forum/topic/new-theatre-of-magic-software-mod-version-2/page/2 it fixed my pet peeve (if the hocus pocus ball save doesnt work it gives you your ball back)
I’m on 1.4h as well, and believe the trunk save ball is an option added in the menu, i’ll have to double check it when i get to my machine
Quoted from Bravebluerx:I’m on 1.4h as well, and believe the trunk save ball is an option added in the menu, i’ll have to double check it when i get to my machine
Yeah my brain is pretty foggy on this. I thought the option was still there in the menu, but it was severely more restricted (like it only gives you the save under certain restrictions)
This page was printed from https://pinside.com/pinball/forum/topic/theatre-of-magic-club/page/63 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
