So the sad part about all of this is that my TOM is going to look SOOOO nice, except one thing... One glaring thing... I've brought it up here in the past, but am really stuck.
So the big positives:
Cabinet holes and damage repaired and new decals.
"Gold-ed" a lot
Color DMD
LEDs (and not the "fruity pebbles" look)
Upgraded speakers/cabinet woofer
Pinduino
Inside cabinet decals
Plus a lot of behind the scenes goodies like auto-eddy sensors, Leon's fix opto board, cleaned trunk gearbox, etc, etc, etc.
Sounds great, right? But I am STILL stuck with that annoying raised (and chipped up) "A" in M-A-G-I-C right in the middle of the playfield.
I was SOOOOO close to getting a usable high quality scan of the M-A-G-I-C area of the playfield. Everything seemed to be looking good for working up some replica decals to just fix the 'A' and have it match the original M, G, I, and C... I got the scans, and the file was huge, but the because the letters can't be lit up while scanning, the image was almost like the difference between a photo of anything on a nice bright sunny day vs. taking a picture as it is starting to get dark... The image just wasn't crisp.
Sending the playfield out to get repaired really starts to get expensive. Heck, WITHOUT damage like this, it seems like general playfield work runs around the $1000 range. Plus that would mean another 3 months or longer without the machine (and ALL of the massive work it takes to strip the top/bottom and more importantly, be able to put it all back together when done).
There is no reproduction playfield (despite rumors of one earlier this year), which would still be pricey, but at least the downtime would be minimal, and you could set up a system where you just transfer things from one playfield to the other (less chance of screwing things up or forgetting where things go).
Thus I was thinking that if I had a nice, clean, crisp, and correctly sized scan of the "A", I could set up a page of decals that others use for restorations where the colors of the A are all slightly different shades of blue, red, yellow, so that I get something that matches and just cut out that one single "A" from the whole sheet. I have to level the insert anyway, so I would take it out, sand off the existing remnants of the "A" then polish it, put on the decal, spray some protective clear on it, and put it back in the machine. It would look a lot better, and play better too (it has been chipped off enough that it doesn't really impact the play at all).
But, alas, I don't know anyone who is able to do a good scan. I've had people try sending photos, and those were good quality, but they weren't generally straight up from the "A" (maybe hand-held camera at a slight angle) so the images turn out a bit oblong.
I toyed with buying another set of playfield insert decals for like $55 or whatever off of eBay, but then the only way to get it to match would be to replace all 5 letters in M-A-G-I-C. I bought a set way back in early 2000ish, but one of the other letters is missing the red part on it. Seriously, how do they make a set of decals, and the one that I would need is missing one of 4 colors (the other colors being blue, yellow, and black).
So I have no idea what I want to do. I really can't afford to put any serious money into this machine after the recent items, but it almost seems like the more I improve things, the more that the "A" stands out.
Here is an old picture from a few years back in 2012. It is slightly worse than this now... I also attached the image from back then showing the missing red on the I on the decal sheet as well.
Just not sure how to cost (and time) effectively make this better....
