Got a few inquires about my Well Walker so here is a "HOW TO" if anyone wants LED eyes in Well Walker.
1. Drill through the glue at bottom of well walker once plate is removed Hole should be big enough for tweezers to get through
2. Drill small holes in Well walker eyes then snake pre wired LED wires through hole and push LEDs far enough to where they are snug and won't pop back out. Extract wire leads from bottom of well walker.
3. If using guts from MEZ make sure to pre mark the hole when guts are mounted to well walker plate, just use a fine point sharpie, this will mark where you need to drill through guts then push through the hole that is already in plate toward the middle
4. Snake wire leads from well walker through plate and guts (if you have them) and then feed them through base holes at bottom of well walker. One wire to left and one to right down the back corner holes then looped into holes at base of well walker mech so they are secure.
5. Make sure to push well walker back so you have slack when ball hits him, but not too much slack. Paint the wire leads red and they look like more intestines. Attach leads to a general GI LED and your well walker looks even better.
