New! Dark mode!
(Topic ID: 173227)
The spring washer: How many of you actually reinstall this?
By chad
  • 22 posts
  • 17 Pinsiders participating
  • Latest reply 2 years ago by phillyfan64
    #1 4 years ago
    I personally seem to just toss these little flexible washers aside whenever I encounter them. You know the ones from the flipper coils used in Gottlieb, Data East through Stern etc... Never had any issues without them. Are they more or less used for eliminating the play between coil and the brackets?
    How many of you reuse them??
    #2 4 years ago
    If there, I put them back in.
    #3 4 years ago
    Quoted from LTG:
    Same with me
    #4 4 years ago
    I always replace them. They actually are important and help keep things from prematurely getting loose.
    My understanding from the physics of them is that they help put lateral tension which will help to keep things tight and decrease the chance of the screws getting loose.
    #5 4 years ago
    I put them back in. They help to reduce or eliminate the buzzing sound from the AC voltage flowing through the coils
    #6 4 years ago
    That's what those are! Have seen them lying around in the cabinet of machines I've picked up...
    "What's with this flimsy warped washer..." ha...
    #7 4 years ago
    yes what they said
    #8 4 years ago
    You would think that the force of the plunger would loosen it up over time regardless of the washer installed or not. Williams/Bally never had them in late model games and i never really noticed any difference in parts loose whether Gottlieb or Data East. Also a lot of times they are cracked and I was lazy in wanting to order them. I will try and replace them and see if any different. Thanks!
    #9 4 years ago
    I think the mechanical designers included them for a reason. Possibly to remove slack, reduce buzzing, and/or act as little shock dampers. I put them in if the game came that way originally.
    #10 4 years ago
    It reduces buzzing, that is all. WPC and Sys11 games (and others) never needed them because they don't duty-cycle their flippers and the flippers run off DC voltage. Older games with AC voltage and newer games that duty-cycle the coil (instead of using two windings for hold circuit) use them to put pressure on the coil to reduce buzzing.
    #11 4 years ago
    I put a new one in every flipper assembly I rebuild.
    rd
    #12 4 years ago
    Quoted from metallik:
    Makes sense , Thank you.
    #13 4 years ago
    They act as a shock absorber and keep flipper coils snug.
    #14 4 years ago
    I always put them back. Keeps the coil from flopping around and having the wires break off all the time.
    #15 4 years ago
    Those are also used in score reels I do believe
    #16 4 years ago
    Some brackets won't adjust snugly to both ends of the bobbin. This allows the coil to move a tiny bit on the vertical plane of the plunger. This movement robs power as the magnetic field is now moving the whole coil in addition to the plunger and everything connected to it. Even a tiny bit of slop robs power from the assembly.
    Also, wallowed-out holes and posts in the link/crank assembly is just as bad or worse for robbing power.
    1 year later
    #17 2 years ago
    I know this is an old thread but are spring washers also used on slingshots? I’m just wondering if it would tighten up the slings on my Mata Hari.
    #18 2 years ago
    Quoted from phillyfan64:
    The coil moving won't effect the sling linkage. More than likely you have slop in the linkage and arm joint.
    -1
    #19 2 years ago
    Quoted from Slim64:
    This exactly. The slings dont use a spring washer.
    #20 2 years ago
    Quoted from Slim64:
    Quoted from Mitch:
    Thanks guys. I actually have new old stock sling linkages and I’m still not happy with these slings. Amazing that my Eight Ball Deluxe uses linear slings and they are way better than what’s on my Mata Hari. If the ball hits in the center it’s fine. If it hits off center, it’s more of a thud than a fire. I had an old thread about this and I never really resolved it to my satisfaction.
    -1
    #21 2 years ago
    Try tighter rubber rings or move some of the slack of the ring to the back side of slingshot.
    #22 2 years ago
    Quoted from Mitch:
    Thanks for the suggestions. I have now noticed that the arm linkages are pretty loose even though they are new. I thought they were new old stock but they may be some kind of repro. Anyway I also have some new Williams kickers that seem much tighter. I never got around to trying them but if the tighter rubber doesn’t work it may be time to try the Williams arms. I may have to modify one screw hole to make the Williams arm fit.
    $ 189.99
    $ 9.99
    $ 175.00
    Professor Pinball
    Bent Mods
    $ 219.99
    $ 48.00
    $ 16.95
    $ 18.95
    $ 159.00
    $ 9,500.00
    Nitro Pinball Shop
    $ 86.00
    The MOD Couple
    £ 20.00
    $ 48.00
    $ 149.00
    $ 84.95
    $ 259.99
    $ 369.00
    Pinball Photos LLC
    $ 54.99
    $ 99.99
    $ 369.00
    $ 119.00
    The MOD Couple
    $ 17.50
    Hardware
    Pinball Art Prints
    $ 32.00
    The MOD Couple
