Quoted from Chrimeg:Pin_Fandango yes I'm always open to trying something new.
I don't use novus 2 as a cleaner. Its used more to help reduce some of the fine scratches left behind by sanding etc. After I've sanded with 3k grit I used Novus 2 and it does help with some of the finder scratches. I don't know if there is a way to remove all scratches truthfully as everything we use has some sort of abrasives that just get finer.
You are absolutely right though. I'm certain there are alternatives we could all be using. In most cases people can only use what available in their area to purchase and what they can afford. Dolphine Glaze is perfect example of that. Great for filling holes on the playfield. However, not available in my area and if I were to buy it online. Its well over $150+ .... so bondo it is. Bondo works but may not be as good as the glaze but its what I can get at a reasonable price in my location.
I think everyone in this community is open to alternatives. Nothing is set stone and some stick with what has proven to work. That's what this community for...helping each other in the hobby trying to keep the older machines going.
thanks,
polishing is not that complicated, but knowing the basics and breaking it down to simple principles is what you need you understand, once you do, then it is not anymore about removing scratches but about material removal.
The grit in the compound makes cuts and swirls, hundreds and hundred of this fine swirls will eventually all match up and make the surface flat. Polishing is like a very fine sanding process that can happen in many different ways depending on the tool you use (rotary, dual action, by hand).
a rotary polisher only rotates in circles and heats up the paint really fast, in the wring hands it will cut through clear quickly specially when polishing an angle.
The DA is like a rotary, but slower and while it also rotates in a circular motion it also does it randomly (although always on the same randomness) and this helps in keeping the heat down, it is easier to polish and renders often times, better results than a rotary (if the rotary is used wrong can left ghosting behind).
The DA is slower, A LOT slower and will take a 30-40 session to polish a PF done at 3000 grit.
when you are polishing you are basically sanding again but this time things are getting flattened, this gives you the clarity to see through the clear coat again.
For those of you worried about burning the clear, the DA is the best. You really have to be a bonehead to burn the paint. The rotary is very safe here too considering the surface is flat so if you keep you hand steady and fast, and check for heat you will be ok. I would personally use the rotary now.
Pads and chemicals needed:
here is where the art is at. You want to combine these 2 according to the type of clear you cutting. The aggressiveness of this combo will determine everything els
your cutting time and material removed and final results (clarity). The clarity will only be as good as your chemical used, if the chemical can only break down to 1000 grit or 2000 grit or else. I think optimum renders 6000 grit at the end of the polishing cycle and starts at about 1200.
The goal is: remove the absolute minimal paint and obtain 98% clarity (you will never know when 100% is reached) but once you are happy you stop.
Happy for me is: no more swirls, the surface is perfect. There are no visible scratches.
If you had a metal substrate you can measure your paint thickness before and after, but since we work with wood you can't. You don to know how much material you are removing here, but in my experience, with a DA, the removal is negligible.
There isn't a fast rule to know what combo of liquid and or paste and pad you need to use, so you will have to try it.
Once you polish the paint and measure your time/results you will know whether you are cutting too fast or too slow.
That said...
For a PF already sanded up to 3000 or 5000 (or any number after 1000 grit) you do not want to use compound. Compound is used for old paint that has been exposed to the elements, bird dropping and has TOO many imperfections so you want to give yourself a good base to polish off. You would otherwise polish all the imperfections to 100% clarity, but the imperfections would remain and the scratches would still be visible. You would end up with a really good clarity but a lot of light swirls and bird droppings would be actually popping out as well (we are talking paint on cars here, therefore the paint droppings example
So, for your PF, once you have sanded it and it is evenly sanded (this step is crucial) you proceed to use POLISH (not compound).
You then tried your softest pad and give it a whirl. Are you on DA? criss cross pattern, you move really slow with a DA and I mean this, less than 5 inches in a 1 thousand -2 thousand - 3 thousand rhythm, If you are going faster than this, flash news: you will be polishing that surface for an eternity. The DA needs a little time to work the surface, go slower than your think you should, keep moving.
You do a criss cross pattern, overlapping all passes, up down left to right, about 6 times. You then measure your results. Are you progressing?
If ou are not progressing, then the pad is wrong (too soft). Get a new pad that is harder.
Try again. One you figure out your pad then you do not have to do this again unless you change your clear coat.
Simple.
Rotary is the same except that you move a lot faster, you do not stay on the same spot and the motion is steady and medium-fast depending on the pad you use.
Anything wool= MOVE FAST.
anything that is foam is very very very approachable. Use foam.
Whether you use a DA or rotary, do no use your body weight to polish the surface, you only use your hands to keep the polisher FLAT. You are not pushing it into the paint, if you are, then the PAD is wrong. your hand weight is just enough to keep it flat.
How do I know how much pressure? this is simple, flat is flat, if the pad is deforming outward you are pushing it in. If the polisher is walking aways then it is not flat. you will figure this out quickly.
You want the pad to work with you and not work for the pad.
Polishing is really rewarding when done right because your realize the potential the paint had once it achieves its clarity to the max. In the case of paints with pearls is really nice to see those shine again, and a good polished clear returns the true paint colours that are otherwise hidden behind an opaque lens (clear with a poor clarity or swirled up).
These are things that I have done to my own vehicles, and clients vehicles while fixing the paint before installing other paint protectants. Merely as a hobby that it eventually turned into a business, lol like most of the hobbies I enter into. Apparently it is an ADHD thing I have been told. I am no longer in the detailing world because I have other priorities and my only hobby is pinball, lol so there is that. But it was nice to use these skills into this hobby.
Last, but not least:
your polish liquid/cream. the clarity you achieve will be determined by this product. Novus will never have the clarity of any clear polishing product because it just can't, it is probably 1000 grit max.
Might as well use any polish, but if you only have Novus go ahead, use it. It will polish, just do not expect it to be amazingly shiny and if it is, congratulations, your prep work PRIOR to novud paid off. anything would have polished that surface the same, including water.
The polish cream I recommended earlier is exceptionally good and easy to work with. It is my go to always.
3m product is also excellent, but to get good THE BEST results you need to go through the 3 steps or it otherwise won't get you the results you want. The optimum cream breaks down as you polish and it does everything in 1 step unlike the 3m product. Optimum is cheaper and perfect for this application.
Anything is better than Novus, please stop using it. lol
